Question about Car Audio & Video
Our headphones, equipped with new batteries, are having trouble getting any audio signal from the DVD player. We know they can work because they did work during a short car ride the first day we had the player installed, but now we aren't getting any sound while a movie is playing.
  • 4,924 Answers
Of the movie is playing and you have image ..tis means that the issue is opn the audio exit ...so check the outlet for the audio ..and cause you do not have any sound at all ..I will go for the direct exit plug ..and see if it is well inserted cause if it was only one side it had to have sound at least the other ...so check all that involve the whole signal...the amplifier..or equalizer if it has attached...follow the signal from the exit in the player ..and see where is the segment with no signal ...I will try some headphones...and folow all the exits ..first plug to see if it has sound on the player exit ..and so on ..until you see where is the issue...If it has separate amplifier ..it may be there if it has signal on the player ..check not to be muted in the settings also ...
Posted on Aug 01, 2010
Only picking up radio stations on headphones after plugging into tv audio
you have to go through the channels til u find the tv signal but the signal only goes to about 4 yrds
Sep 21, 2013 | Meridian Point 6 in 1 Wireless Headphones...
Im trying to hook my insignia flat screan tv to my mitsubishi M-VR900 recevier the tv has plug for audio out and recevier has a tv audio in red/whit plug and i have 2 speakers i have on the front spearker...
Go into the onscreen menu of your TV, find and select the audio options. Make sure the audio out on the TV is enabled (this might be an automatic feature and might not be displayed -it depends on your TV model). Next make sure your receiver is working and (if it is so equipped) make sure your speaker switch is enabled.
Make sure all of your cables are working. You can do this by switching out the cables one at a time for ones you know are good.
Make sure no headphones are plugged into your receiver or the TV -this usually turns off your audio signal to any speakers.
Your TV remote may be equipped to control the volume output of the external audio out signal. Some TVs automatically turn off the internal speakers when you hookup or select an external audio output. turn up the volume on both (your TV and the Mitsubishi).
Does the Mitsubishi work on other sources (DVD, radio etc...)?
Remember to double check your cable connections -audio OUT from the TV to audio IN into the Mitsubishi. Reversed connections can damage your TV and amplifier electronics.
What model is your Insignia? Some are equipped with digital outputs which, if your receiver is so equipped as well, can send surround sound (home theatre) signals to your receiver. These can be orange-colored rca jacks or optical jacks. They do not send analog audio signals.
Once all the cables are double-checked, (double-check your speaker connections!), turn on your receiver, TV and signal source (cable, satellite DVD etc...), bring the volume control (both on the Mitsubishi and the TV) up to nominal levels. You should hear sound.
One more thing:
Make sure your speakers work. You can try them on another amp or simply touch the speaker terminals with a 9-volt battery (the speakers should move in or out depending on the 'phase' of the connection).
Hope that helps.
Nov 26, 2011 | Audio Players & Recorders
Hello Could you tell me how to get the infrared
Hello... I am sorry to hear you are having problems. I am unsure if you bought this as a package deal with the headphones or purchased the headphones separately. If you purchased them separately, they may not be compatable. Headphones come in different frequencies. The reason for this is if you had 2 different dvd players and 1 kid was watching Spongebob and the other kid was watching Hannah Montana, they would not interfere with each other as far as sound. Some dvd players will allow you to change the output frequency of the IR (infrared) transmitter built into the dvd player. This feature would be in the menu section of your dvd player. Make sure the headphones are on properly, because if they are backwards, they may not read, because IR frequencies are "line of sight" meaning the receiver (headphones) has to see the transmitter (dvd player). You will see a tinted window that has 3 or 4 bulbs. That will be your transmitter. Make sure you have good batteries in the headphones and that you have them turned on. If you have power and have checked the IR frequency, and they were purchased aftermarket, then you may need a different set that receives the correct frequency. If this is a package deal and you have checked the batteries and they power up properly, you may have a bad IR transmitter inside the dvd player. With the info you provided I can only speculate at this point, but this gets you on a start. Let me know if I can help more! Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | NextBase Click 7 Duo Car Video Player
Portable DVD PLAYER: I don't get any audio. I'm batteried-up, plugged in, volume high, remote working, picture good -- just no audio. Any suggestions:
Maybe it has a failure in the audio amplifier, if there's no sound even with headphones or the internal speakers, if there's audio only with headphones.
Feb 09, 2011 | RCA DRC620N Portable DVD Player
No audio through headphones
Hello, Had the same problem with my Rosen Headphones (see my entry on the 20 Aug) Take the batteries out of them and leave them out for at least 24 hours, put the batteries back in and they should work OK. I think the problem with my ones were that I did not use them for a few months but left the batteries in. So when not in use I wont be leaving the batteries in. Please note they will turn themselves off if they don't receive any IR signal after 3 mins.
Jul 11, 2009 | Rosen A7 Car DVD Player
Audio trouble
Is the mute button on the dvd player on? Have you tried turning up the volume on the DVD player, have the speakers been working before? Have you always got headphones plugged in? Have you checked the audio setting on the DVD player?
Nov 01, 2008 | Televison & Video
How do you work the sound on the DVD player?
I have a 2005 with DVD - but do not have the wireless headphones. I use the AUX button on the front radio to switch between FM/AM/and the DVD Player. I do have headphones jacks in the roof console by the DVD player, but have never used them.
Aug 06, 2008 | 2006 Chevrolet Uplander
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
There is no sound in my equipment
I have the same problem -- just bought a used minivan and can't get any audio with the DVD player. Were you able to find a solution? Any help would be appreciated! Thanks
Dec 06, 2006 | Clarion OHMD74 Car DVD Player
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
