Question about Whirlpool Dryers
Whirlpool, ultimate care ii, elec dryer, thermal fuse blown, bypassed to check out and now only one temp it cuts out at 150 no matter what setting i have it on. What could be the problem?
    President:
  • 2,030 Answers
The timer/controller circuit is bad, and you may have a bad heating element.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
Ultimate care ii dryer thermal fuse
Thermal limiters should reset automatically. More likely is a breaker has tripped. turn off the power FULLY and somewhat forcefully, then back on and test again...
Nov 19, 2011 | Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool leb 6000 pqo will not heat
    check heating coils, high limit, temp selector switch.
    Apr 05, 2011 | Whirlpool Dryers
    Whirlpool Ultimate Care clothes dryer heater does not come on
    First verify you have 220 volts of power at the terminal block on the rear of the dryer.
    If power is OK use your volt meter set for continuity and check the door switch. With the door closed it should get a reading.
    Finally,remove the rear panel from the dryer and check the thermal fuse located on the left of the main exhaust duct. It is about 1 and 1/2 inches long by 1/2 inch wide and white in color.
    Remove the 2 wires and check for continuity with the meter.
    No continuity is a bad fuse.
    It is replaceable,not re-settable.
    Sep 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
    There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
    Jan 02, 2010 | Whirlpool Dryers
    Whirlpool LEQ7030K90 Electric Dryer (ultimate care ii) 2001 model emits a buzzing sound when the start button is pressed. Unit will not heat or turn the drum.
    CHECK TO SEE IF YOUR THERMAL FUSE IS OPEN(BLOWN) IT SHOULD BE LOCATED ON THE BLOWER HOUSING. GO TO www.repairclinic.com and look for part number 2986 after you enter your model number. If it is bad you also should replace the high-limit cut-off fuse located closest to heat element.
    Apr 12, 2009 | Dryers
    Cant find the fuse on my ultimate care II dryer?
    The thermal fuse is usually white plastic about 3/8" wide and about 1 1/4" long
    Mar 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Dryers Logo
    498 people viewed this question
    Top Whirlpool Dryers Experts
    Tim Whalen
    Sal De
    Craig Butler
    Craig Butler
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
