Question about Whirlpool LGR5636L Gas Dryer
I have a gas dryer and it does not get hot.. Are there some simple checks I can do before I trash it??..
  • Whirlpool Master
  • 1,606 Answers
Pull the dryer out and unplug the dryer . Then remove the back panel . On the blower housing , you will see a 1" ling white piece , with 2 wires going to it . Disconnect the wires and hook them togather . Plug in the dryer and start it . If the dryer heats , replace this piece ( thermal fuse...pt # 3392519 ) .
Posted on Aug 01, 2010
  • keywest41 Dec 27, 2010
    This was it. When I checked this with a multimeter it was open. Shorted two wires together and the igniter fired up. Do these go in age or should I be looking at a cause to this fuse going. All air paths are clean and clear as I clean dryer internals regularly.
    Unit is a whirlpool LGR7646EQ3 and is about 12 years old
My clothes will not dry. Air blows, but it does not get hot. I have a gas/electric dryer. It is a Kenmore dryer 70 Series.
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 27, 2011 | Dryers
My dryer is not blowing hot air.
Since yours is a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is not shooting hot air to dry the clothes
Since you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
This is a gas dryer and it will not get hot
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 25, 2011 | Maytag Dryers
My whirlpool gas dryer is turning and air is working but it is not getting hot
Jul 25, 2011 | Whirlpool Dryers
Dryer will not get hot. Is there something simple that I can check before calling a repair man?
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Make sure gas supply is on for gas dryer, Clean the lint filter and exhaust duct.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Kenmore 73952 Gas Dryer
My Maytag Dryer (Model: DG612 , Series: 05) stopped producing hot air to dry the clothes. I opened the little door on the bottom right hand corner on the front of the machine and noticed that there was no...
Replace the ignitor you broke and check gas valve coils for continuity (they should be in the range of 500 - 2000 Ohm, don't remember exactly). Very likely one of them has failed.
Part numbers for the ignitor (any will do, they're identical):
4391996
WE4X750
5303937186
Part numbers for gas valve coils (complete kit, also identical):
279834
5303931775
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | Dryers
My kenmore gas dryer model 65761 stopped heating up, any suggestions?
I would suggest checking the hot surface ignitor. This is what lights the burner to give the machine the heat. It is usually located at the lower rear right side near the burner tube and glows red hot when the dryer is turned on. It usually has two white wires going to a plugg and held in by a couple of screws fairly simple to replace once you get to it. Probably have to take the front of the dryer off to get to it.
Jan 19, 2010 | Dryers
Dryer gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2008 | Kenmore 74112 Gas Dryer
Whirlpool LGR5636L Gas Dryer Logo
295 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
