Having trouble with my Miele Touchtronic W1213. The drain continues to run and the display shows "---" while the buzzer sounds. We've tried to turn off machine, drain the drain plug, lower the waste water hose, etc. We've had no luck. I turn off the machine after a few minutes so the drain motor does not burn out. Can you please help?
    Problem Solver:
  • 15 Answers
Most likely the float switch is tripped in the lower pan. This means a leak or oversudsing happened. If the machines aren't stacked, try tipping the washer forward to empty out any water. Otherwise, call service at 1-800-999-1360.
Posted on Aug 01, 2010
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and...
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Dec 31, 2010 | Miele Touchtronic W1213 Front Load Washer
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
W1213 Touchtronics intake and drain light is blinking
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
Feb 02, 2018 | Miele Touchtronic W1213 Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
