Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
We Have a Sony KDF-50WE655, we've replaced the lamp and housing and we still have no picture or sound. Can you help?
  • 10,594 Answers
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check.
If still no picture or sound then check power/standby light is blinking?
If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem.
Thanks.
Posted on Aug 01, 2010
SONY WEGA KDF-50WE655 PICTURE IS DARK MY LAMP IS ONLY 2 MONTHS OLD
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Jun 13, 2016 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony 3LCD tv picture and sound goes on and off, what's wrong?
How old is your TV have you replaced the lamp already this lamps are made to last a avarge of
2-4 years of use if you have not replaced the lamp before that would be the first thing to do but if you already replaced the lamp recently and have this issue then it will be a BALLAST issue
I found the lamp you need just incase
http://www.discount-merchant.com/SearchResults.asp?Search=KDF-50WE655
PLASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!
Oct 13, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the lamp and my tv still don't work
i have a sony kdf-50we655 tv and replaced the lamp. it still does not work green light blinks and then it powers down right away.
Feb 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hi, i have a sony wega kdf-50we655. My tv just turned off for no reason after i turn it back on i waited and the standy by blinks green for a minute or so then it turn red and i notice the lamp indicator...
Yes. Be sure to push the new lamp housing all the way in until it's fully seated, and make sure you replace the access cover properly as well or the replacement lamp will not work.
Dec 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50 in picture is dark
I had the same and replaced the lamp - made a big difference. Got the bulb on Ebay for $82.00 with free shipping. Just the bulb without housing, seller has instruction online for changing bulb - very easy. River Valley Electronics
Here's a link
http://cgi.ebay.com/XL2100U-XL-2100U-A-1606-034-B-A1606034B-LAMP-FOR-SONY_W0QQitemZ370154719357QQihZ024QQcategoryZ149975QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Mar 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony lcd kdf-50we655. alot of blue spots. now..
Yep. New lamp. I believe that it is an XL2100U for the kdf-50we655. Should run about $200.00.
If you have your original owner's manual, it will walk you through changing the lamp. If you do not have it, then it should be available to find the manual on the support section of SONY.com or on Sonystyle.com.
I hope this helps you...
Jan 20, 2009 | Sony KDF-E55A20 55 in. LCD Television
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
250 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
