Question about Kenmore HE2 Plus Front Load Washer
Can the door on this dryer be swtiched easily? (from right to left....) Can't find manual. Thanks. MD
    President:
  • 2,030 Answers
You can get the manual from sears or searspartdirect.com
However the door cannot be switched on most of those models.
Posted on Aug 01, 2010
Creda 37761 problems drum will not turn heating up
OH OH SOUNDS LIKE BAD WINDINGS ON THE MOTOR, HAD THIS PROBLEM LAST WEEK , THE MOTOR WAS SHOT AND WOULD NOT TURN THE DRUM, I TESTED IT WITH MULTIMETER AND MANUALLY, BY OPEING UP AND TAKING BODY OFF THE DRYER, remove the drum and belt, JUMPING THE DOOR SWTICH, AND THEN STARTING THE DRYER, BINGO It the motor STARTED RUNNING, but when I put body, drum and belt back on BINGO no running or turning.
Sep 14, 2014 | Dryers
Have F09 fault code on dryer
I think the 09 code may be for the door switch. I have the Kenmore HE2 gas dryer that would turn off mid cycle and not turn on again. A repairman came to try to fix it. He thought the control board was the problem because there was a saved fault code for F-01 which is the control board. When he replaced the control board the same problem happened. He couldn't fix it. I went through the diagnostics and an "09" code comes up right after the saved F-01 code. The dryer failed the door switch test and it says an 09 code indicates the door switch is faulty. I haven't purchased a new door swtich yet to see if this will fix the problem. Good luck. Peter
Aug 06, 2010 | Washing Machines
The dryer door won't stay closed on my 90-series electric. Doesn't matter if the dryer is running or not. Have to keep the door closed by propping a weight bar against it. Any suggestions to get this...
There is a door catch made of plastic that holds the pin thats sort of arrow shaped on the door... The plastic catch is located on the front of the panel and can be easily replaced....Call the local repair shop/man to get the part....very cheap part maybe a couple of dollars at most... You should be able to remove the broken one with just a set of pliers and a screw driver...doesn't matter anyways its already broken right!! the new one will push and snap right in....Good Luck
Apr 20, 2010 | Kenmore Dryers
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
How do I reverse the door to open r to l
You would need to refer to the user manual for that model. See IF it has the ability to change the door swing. If it does, it will tell you in the manual how to doit
Feb 24, 2009 | Speed Queen AES28AWF Electric Dryer
2003 Civic left Side Electric Door lock Broken
bye a diff car hondas are nothing but problems
Feb 10, 2009 | 2003 Honda Civic
Washer door opens with hinges on the left
Don't you think it would really boost sales if you did make a washer that the front loader door could open left to right . For homes that have very limited laundry room. and no way to switch.
Dec 28, 2008 | LG WM-2277HW Front Load Washer
Dryer wont start
open door and spin drum to left then right.
Oct 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore HE2 Plus Front Load Washer Logo
59 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
