Question about Garden
Disconnected wiring. where does it go? wiring has been cut on a Robin EH34 engine used for a nac 6200 generator
    President:
  • 2,030 Answers
Without a picture or better description of the wiring its hard to say.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
I have Honda generator 4100 with remote start it will start and run untill u let off botton light on remote switch went out how do dy pass switch
PDF]SERVICE MANUAL - Electric Generators Direct
www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Hond...
associated with operating your NAC portable generator, following the precautions listed below will assist you in .... For detailed engine information, refer to the Honda Engine Shop Manual. Note: ? ..... (e) Do NOT remove the diodes or de-solder the wires attached to the diodes. (f) Ensure you have ... NDK-4100YE. WIRING ...
Aug 04, 2015 | Honda Electrical Supplies
I need a new robin subaru thottle body r1100
I believe this generator uses a carburetor.
Try calling Jack's Small Engines during their business hours; I don't see a carburetor listed separately and it may be very expensive.
Robin Subaru R1100 Generator Parts Diagrams
You may be able to just clean the carburetor you have and save a lot. The video isn't the exact engine but it is close.
Feb 08, 2015 | Subaru Cars & Trucks
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
Robin engines won't start
Look for kill switch. Make sure it is wired correctly and not broken or something like wires no connected. It cuts spark when activated so likely the problem since its in-line with exciter.
Jan 04, 2014 | Coleman Powermate Premium Plus 6250...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
After unboxing and setup genpower 305 will not start
Hi and welcome to FixYa, I am Kelly
The generator has a low oil level sensor. Make sure the oil level is FULL all the way to the point oil comes out of the oil fill port when you add oil. If after your sure it is full of oil it still does not start then disconnect ONE wire from the oil level sensor and check for spark.
There is a model number on a data plate that begins with "PM" like this:
PM0435005
This model came as a manual and an electric start so the model number is important. The engine on this model is a Subaru engine and my experience with Subaru engines it that the low oil level sensors are extremely sensitive to even the slightest drop in oil level. (Good engines though!)
There should be a fuel selector that you need to turn ON and a Choke lever that you PULL and then push in upon start.
This should be and EH34 or EY34 engine.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
I have a Robin 6.0 gas engine, model EH-17, on a Titan Industrial TG-3750 generator. It starts fine, but the rpm varies for a bit then settles down. Once a load is put on it, it goes to full throttle,...
There is most likely debris in the float bowl especially in the bowl nut area. The sputtering is a lack of fuel flow. The governor is doing it's job... the carb is not keeping up with the governor demands. Take off the float bowl and clean out the bowl, the bowl nut and the jet in the threaded area where the bowl nut threads into. Then with the air cleaner removed... spray carb cleaner in to all of the brass holes you see, One center bottom of venturi throat, Just note I have seen the NGK BPR5RS spark plugs cause this same symptom. I have an EH34 11.0 Hp Robin engine on my generator... and have worked on generators since the late 1960's
You did not methion the age or estimated usage hours so, I am assuming this generator is not heavily used. If it is..a high usage generator the next time it throws a fit... try holding down on the butterfly (Gently) in the center post area to see if air is being drawn though the butterfly pivot area.
I think just by cleaning things up per directions above you should be fine.
Kelly
Nov 02, 2010 | Electrical Supplies
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
