Question about Kenmore Kitchen Ranges
Reinstall RANGE HOOD from non-ducted to ducted
KENMORE ELITE RANGE HOOD - MODEL# 233.55213.000
I bought a home that has this installed, its installed non-ducted. I want to duct out. My contractor says he needs to know the size of the duct needed to attach. What is he going to need to reinstall. I am assuming the duct access plates were not knocked out in the original install, so that should be punched out, anything else needed to attach to duct? what size opening on the duct? the duct will go up through a cabinet a few feet then an L turn left straight out a kitchen wall about 3 or 4 feet.
  • 8,197 Answers
You need to uas a 7 inch duct to duct it out. You can get all the info you need in the manual on the link below. Please give it some time to load. If you need parts you can call Sears at 1-800-4-MY-HOME.
http://www.managemylife.com/mmh/owner_manuals/2285/KENMORE-Range-Hood-L1002022?brand_name_search=233.55213.000+
Good Luck and please rate 4 thumbs up for the free answer
Posted on Aug 01, 2010
Testimonial: "thanks"
Kenmore microwave hood combination
If you have tried to reset the microwave oven by turning the mains power off and on without success then it is likely the display is faulty.
The only way to repair is replace the control panel board. This can cost a lot of money.
See this site to give you some idea. Best to contact a repair technician and get an idea of costs.
KENMORE ELITE Microwave Range Hood Controller Parts Model 72180839500
Aug 03, 2014 | Kenmore 1.4 cu. ft. Speedcook Microwave...
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
I instaled kenmore elite range hood but is too loud
They are all very loud... when you are moving air like they do it makes alot of noise...
heatman101
Feb 07, 2011 | Kenmore Kitchen Ranges
I have purchased a 1960 house with a Kenmore 850 range hood. I want to install my Dacor 30" 4-gas-burner range (about 14 years old and brought from my former home) and need to know if the CFM of the...
No problem Be sure the duct coming from the range hood is the same size of the duct through the roof , Or it mat be a vent that don't vent to the outside, IF so throw it out , and get a vent that vents to the outside , Or get use to smelling the odors of all your cooking inside your home
Sep 28, 2017 | Kenmore Kitchen Ranges
Need to reinstall Kenmore Downdraft Blower
If I can get the model # I can help you more with the removal and reinstall.
May 28, 2010 | Kenmore 59940 Kitchen Hood
Range Hood ductwork.
The range hood will give off only minimal heat from cooking. You should be fine with what you are using.
If you read the directions on the can of great stuff it will tell you everything it can be used on and what the temperature rating is.
Oct 02, 2009 | Maytag Generic 30 in. Range Hood
Kenmore elite 36" downdraft dimensions
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Mar 11, 2009 | Kenmore 59940 Kitchen Hood
Instalation instructions for kenmore range hood model 50303
You should be able to find the manual here:
http://www.managemylife.com/mmh/owner_manuals/13409/KENMORE-ELITE-Range-Hood-L1004363?brand_name_search=kenmore+50303
The file name is L1004363.pdf
Jun 07, 2008 | Kenmore Italian Design 50303 Kitchen Hood
Light doesn't work on Kenmore Model 55022 Range hood...
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Apr 05, 2008 | Kitchen Ranges
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Kitchen Ranges Logo
664 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
