Question about Raymarine C70 GPS Receiver
My C-70 boots up with lines in it, can not see display at all. I bump the display and reboot and it works, I have checked and cleaned all cables. Don't want to get off shore and get let down.
    Problem Solver:
  • 6 Answers
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes,
The solution is simple: press on the edges of the screen and the contact is re-established.And next time when you moor the ship, don't put the cover over the plotter till it is dry :-)
Posted on Aug 24, 2010
Vertical blue and yellow lines on dispaly
Sounds like booting problem from hard disc. The disc might have damaged due to fall. Replace it; reload the O/S and check.
Gopakumar Gopalan Google
Apr 19, 2014 | Toshiba Tecra A9-S9021V Notebook
First boot displayed but did not finish booting. later i tried again system unit do not display
when you enter the computer press Del and go t bios then click load fail safe configration then click save and exit and reboot your computer if no check the power cable IDE cable or sata cable for any loose contact
Apr 26, 2011 | Evesham Evolution PC Desktop
Hello my Acer Aspire M5640 just crashed it powers up but bios does not boot up can you help thanks I pulled memory out and cpu fan and power supply fan are on
If you have no 'BIOS' startup display, try:
  • Unplug the PC from the main AC power to force a hard reset. Reboot and test.
  • cleaning the memory board 'gold' contact with a white soft pencil eraser and swap them around if you have a couple. Reboot and test.
  • using a single memory board if you have more than one. Reboot and test for each memory board individually.
If you have 'BIOS' startup display, but fail to boot, also try:
  • Check and re-seat all external and internal cables (HDD, USB), and PCI cards (eg. Video)
  • Check Bios setting expecially for HDD
Hope it helps and good luck!
Jan 07, 2011 | Acer Computers & Internet
Sir,when i turned on my system nothing displaying on my monitor,i can hear a beep sound.wat problem is this?
Hi,the beeping could be as a result of a faulty or slightly shifted Memory,or Display cable not properly connected,so check and let me know how many times it beeps.thanks
Jan 07, 2011 | Intel Motherboard
IN NOKIA 5200 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALLOWED nokia 5200 gprs setting when I try to save it will say only 70 sets allowed setting discarded
Nov 06, 2009 | Nokia 5200 Cellular Phone
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
My computer does not display and yet it keeps beeping
There are some loos cables. Try unseating the RAM, clean it & put it back. Check that all power and IDE cable along with the 24 power pin is snug tight. Reboot and try to enter BIOS. Set evrything to default and try to boot in safe mode and then "last when it worked best". That should do it, else try booting from CD and repair the OS......sodeep
Apr 06, 2009 | IBM NetVista PC Desktop
Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
Mar 04, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
HP monitor goes black and asking for frequency settings
If you see the initial boot screen until windows boots then you may have a setting for the refresh tate too high in Windows. Try starting in VGA safe Mode by hitting F8 during boot. Once there you go to control panel, Display, settings tab,Advanced and choose monitor. you'll see a refresh rate, try setting it to 60 or 70 and see if it works on reboot.
Be sure to use the VGA option...its ugly during the session but will let you reset the rate.
Good Luck!
Jan 07, 2009 | Computers & Internet
Display has bars and lines when it reboots
BACK UP COMPUTER RUN RESTORE DISK THAT CAME WITH SYSTEM TO RELOAD VIDEO DRIVERS AND RETRY
Jan 23, 2008 | Toshiba Qosmio G15 Notebook
Raymarine C70 GPS Receiver Logo
128 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
