Question about Sony Ericsson Satio Cell Phone
My satio touch screen is not working properly i want to replace that what i do ? whats the new touch screen rate?
  • 944 Answers
The replacement of the touch screen is very simple.The cost of touch screen is £28.99.Have you calibrated your phone?
The steps to recalibrate is quite simple
Go to control panel menu-Setup wizard
tap 'YES' before cancel appears.Do this until you see 1,2,3,4
numbers blinking...
If still your problem is not solved this will be caused because of two reasons
1)Touch screen- will not work only when you drop it or Liquid in it is damaged.
2)Touch screen sensor
2)Keypad IC.
Touch screen sensor or keypad IC cost is very less you can replace it or solder it if it is loose.If you don't have hands on in it please don't try it you can take it to nearest service center.
The replacement of Touch screen is quiet simple.
The replacement can be done.follow the steps.
1)remove the battery and Sim card.
2)You can find screws now.so open the back and front panel
3)Be careful the LCD and the flex is being joint.so care fully remove it see how the flex is joint with the motherboard.there will be thin film like connection between the two.
4)Take the LCD you bought..In the image you can see gold type film that is flex.you have to place it perfectly.That's it
5)Close the phone.and now enjoy working with it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 01, 2010
  • cookington Jun 05, 2011
    i would advise people to NOT try to do this themselves, i am now the sad owner of a ruined satio! the gold connector was stuck in an is VERY hard to get at, after removing it (in several pieces) installing the new touch screen was impossible, leave it to the pros!!!!
  • sparky543uk2
    sparky543uk2 Mar 06, 2012
    Perfect! If you follow the instructions, it's easy. Thank you changed in about 10 minutes.
Sony ericsson satio body wants
you have to change the screen all together if the sensor is not active anymore because u can't get a sensor without the screen
Oct 18, 2012 | Sony Ericsson Satio Cell Phone
Touch not working properly
reset the phone & the calibrate the touch sensor from the setting. After that try. Thanks.
Dec 19, 2010 | Sony Ericsson Satio Cell Phone
Satio touch screen not responding at all? buttons and camera work ok, not dropped and no water damage. cant do a reset because I cant use the buttons? please help
Ur problem is because of short circuit inside ur phone .u cann't solve this problem on ur own u have to go to nearest mobile service center.
Aug 22, 2010 | Sony Ericsson Satio Cell Phone
Unresponsive/slow satio.
Hello and Welcome to FixYa!
Yes sure, you should try to upgrade your firmware before spending any money, its easy as 123, all you need is the Data Cable (That comes with a new piece) and an active internet connection.
If you have them, just visit the link I've provided below, there you will get all required information/guides and the Download Utility. After downloading and installing, run it and the wizard will guide you on how and when to connect your phone, I'm sure that your issue will be resolved because it seems like a firmware malfunctioning. Its worth a try. Try it and do share the experience.
If you are having trouble/questions, do ask me, We are here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Satio Firmware Upgrade
Jul 29, 2010 | Sony Ericsson Satio Cell Phone
Touch screen not working properly, i touch down part of screen and it activate upper options. upper part of screen not responding
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 28, 2010 | Samsung SGH-D980 Cell Phone
Phone went dead and now the touch screen wont work. i cant put my access pin in through the keyboard so it wont open. What do I do?
TOUCH SCREEN
Take care.
Jun 28, 2010 | Cell Phones
Satio touch screen faults
Hi
I would advice that you loose the phone with a phone screw driver then remove the screen.Make sure you handle it with care in order to avoid damage.
After that then you would have to check if the screen is still good or no longer working.if it is damaged there would be a sign of something like ink.
If you observe that then you need to replace the screen.
THANK YOU
Jun 15, 2010 | Sony Ericsson Satio Cell Phone
My touch screen on my htc touch HD is not working properly...WHat Should I do?
how can i do that if my touch screen isn't working ...i can't start my phone...:( what can i do?
Mar 17, 2010 | HTC Touch HD Smartphone
Just got my sony ericsson satio replaced but no vibration.
I would get it replaced again under warranty, as it doesn't do something it is advertised as being able to do. Check the total amount of calls etc in the phone log just to see if your supplier has issued you with a refurbished unit as a replacement!
Dec 23, 2009 | Sony Ericsson Satio Cell Phone
Sony Ericsson Satio Cell Phone Logo
3,264 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
