Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
Electric pto will not engage the mowing deck. stopped working while mowing.
    Problem Solver:
  • 4 Answers
Had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
Posted on May 01, 2011
Kubota zd28 mower was running fine put away but now PTO wont engage.
if your saying that pto wont do anything , that's either an electrical short or a broken belt , in rare cases the clutches go too , now if your saying the pto engauges and stalls the engine or makes horrible noises , then that's a bearing , im betting the deck shaft bearings are in need of some serious grease work
Mar 04, 2017 | Kubota Garden
Why doesn't the PTO engage the blades?
assuming the PTO is an electric clutch engagement ? if so you must not be getting voltage to it. also you may have a safety switch restricting voltage from getting there. i have a rider that has this type of PTO and if my battery gets low mine will cut in and out as i mow. i charge my battery and then it works just fine. check for voltage at the clutch and also you can check continuity of the switch itself to make sure it does work. hope this is some help
Oct 13, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
Engine stopped while mowing...tried to restart...nothing.
I am having the same problem. The PTO in engaged and won't relase. The engine won't turn with PTO engaged, you need to disengage the blades to restart.
Jul 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
2,093 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
