Question about Samsung (SP1203N) 120 GB Hard Drive
I could not hardisk detect on pc when decting hardisk,please boot another disk
    Brigadier General:
  • 10,406 Answers
Check that the "data" and "power" cables to the disk-drive are fully-connected to the disk-drive.
Check that the "data" cable is fully-connected to the motherboard.
Enter BIOS SETUP, and check that the motherboard has detected the disk-drive.
Otherwise, your disk-drive has "died", and must be replaced.
Posted on Aug 01, 2010
The computer does not boot into the operating system and displays "Operating System not found."
For that problem, do this first check-up your bios setting.
Power on your PC laptop
, when screen popped up ( press F2, delete etc. ) to get into standard bios Setup you see there if your hardisk drive detected or not detected. if not detected try to open your Laptop PC ( need power off. open cover at the back of your laptop ) check-up your hardisk drive for loose power cable, data cable hardisk Some burn , noise hardisk sound ) if detected, your operating system corrupted. you need to Reinstall your operating system like windows xp, windows 7 or linux base operating system. try that Solution first.
Just let me know if not yet working your laptop PC.
Regard.
Aug 26, 2011 | Toshiba Satellite M30 Notebook
My hard disk have problem if i open may pc in go to 2 my os he said disk boot failure what can i do pls help me pls.
Kindly Try this:
1. Restart your PC
2. Repeatedly Press F9 (Window must appear with list of Drives on it)
3. Choose the drive where your OS is installed.
Hope that this help.
Else give me feedback for me to get back to you.
Mar 16, 2011 | Computers & Internet
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
This message comes up after I turn on my laptop and it is trying to start up "no bootable device -- insert boot disk and press any key" How can I fix this problem? Thanks.
the hardisk cannot be detected. On system bios... press"del" to enter bios,(on other computer its "F2") ..on the BOOT tab check who is the first booting device. set hardisk (ide) as your first booting device by pressing"+" sign. On the bios you can also check if hardisk is detected, if not then your hardisk crashed.. need to replace it.
May 17, 2010 | HP G60-230US Notebook
When i boot up my pc i only see the message "intel desktop boards" and the intel pentium 4 logo and the pc won't go through the boot sequence but stays at that screen. What does that mean? Has the board...
have you check BIOS settings....when turning on press DEL key to go to your BIOS settings...please disabled your other boot up except your hardisk or cdrom.....in your boot up sequence choose your hardisk....itf still keep f\lashing check your hardisk if its detected.
Oct 15, 2009 | Intel Desktop Board D845WN Motherboard
My dell gxa is detecting cdrom but does not boot with 98 or xp and after a while it goes to hard disk.....
try to change your booting setup in your bios maybe it reads first the hardisk not your cd rom.
Oct 06, 2009 | Dell OptiPlex GX1 PC Desktop
Samsung (SP1203N) 120 GB Hard Drive Logo
174 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
