Question about Lakewood HV 18-c Floor / Box Fan
Motor just hums, won't turn - Lakewood HV 18-c Floor / Box Fan
  • 10,319 Answers
If you remove the cover screen and take compressed air or just a brush to clean out all dust and dirt from the motor the fan may run again
Dust is a standard contributor of these fans to quick turning
Posted on Aug 01, 2010
    New Friend:
Ball bearing bad maybe mine seem that way. when i turn it on the inner shaft gets stuck against the electro magenet cause bEARINGS ARE NOT HOLDING IT IN PLACE.
Posted on Jun 16, 2014
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
My dryer was in the rain and now won't work...just hums
If the motor just hums and it will not rotate the drum, you will need to replace the motor. Here is the motor to order.
Nov 18, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Freezer won't turn on
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Sep 12, 2012 | Kenmore Freezers
Motor hums but won't start
Most problems with humming motors are with the power input TO the motor (Not enough power to turn the motor)
I'm guessing it is a single phase compressor? If you have it connected to an extension lead, then, if you can, try plugging it directly into the wall, (you can lose vital power through the long lead itself) Second the capacitor attached to the motor could be on its way out or shot. You would need to get it tested, or if you notice anything bulging out of it, then you know it needs replacing. If all the above are ok, then you would need to get the motor itself checked out by an electrician, the bushes or coils are probably gone
Hope that helps
Sep 10, 2012 | Air Tools & Compressors
Jacuzzi 1hp hums won't turn on
If your motor is turned on and just hums then it is bad and will need to be replaced.
Rod
US Parts Center
888-521-6183
May 29, 2012 | Jacuzzi Impeller, L - 3/4 H.P
I have a CH 8 gal compressor that won't run. When you turn it on it just hums for a couple of seconds then stops. You hear a click and then your able to turn it on again but it still just hums
Remove the air out line and the motor. Try to turn the motor and the compressor by hand. You have a seized bearing somewhere. Bearings are available at any power transmission shop for a few dollars.
Feb 04, 2012 | Campbell Hausfeld Air Tools & Compressors
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Replaced motor,now won`t spin
Something is locked in the transmission--can you turn the inner tub manually? Also, try to turn the driven pulley (the motor and belt driven). The problem could be anything from a seized bearing to a broken gear. Don't keep trying the motor while things are locked up, you could burn it out.
Aug 18, 2009 | Washing Machines
Lakewood HV 18-c Floor / Box Fan Logo
1,006 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
