A wire of length 12 1/2 m cut into 10 pieces of equal. Find the length of each piece ?
    New Friend:
    Problem Solver:
  • 10 Answers
12.5 meters = 41.01049868766404 feet = 492.1259842519685 inches
492.1259842519685 / 10 = 49.21259842519685 inches per section
There are 2.54 cm in an inch, therefore:
49.21259842519685 x 2.54 =
125cm for each piece?
Posted on Aug 01, 2010
SOURCE:
I have a Homedics SBM-300. Dog chewed through all 10 wires on the remote. Easiest way to splice wires back together?
Best solution is to replace the cable and possibly the dog. If you insist on repairing the cable I suggest you get a length of fine heat shrink tubing and cut 10 pieces about 1cm long. Then cut each end of the cable to give a clean end. Strip about 2cm of the outer insulation from the two cable ends and then strip about 1cm from each of the 20 inner wires. Then using a soldering iron tin each of the bare ends. Slip a piece of the heat shrink that you earlier cut over each of the wires and then solder the wires together ensuring that you match the colours correctly. Move the heat shrink over the bare solder joints and use the hot soldering iron to shrink the tubing. Finally cover the whole joint with insulating tape.
Feb 10, 2018 | Homedics Health & Beauty
I want a 1.8 stitch length to paper piece ... I can't figure out how pfaff creative changes to 1.8
Looks like your machine's stitch length ranges from 0-6 mm. So you are looking at something just under 2 mm--there very possibly is a 1.8 setting on your machine. Basically, your paper piecing instructions are telling you to set the machine to stitch somewhere between ~12 to 14 stitches per inch. The accuracy of 1.8 is Not that important. What they are trying to do is make sure your stitches are close enough together to make it easy to tear away the piecing paper. When using longer stitches for paper piecing, it is sometimes difficult to tear away the paper without pulling the thread stitches. Most garment stitching is set between 10-12 stitches per inch. So you want something just a little closer together, ie more stitches per inch. If you are concerned, try it out on a scrap piece of paper and fabric and try tearing it away. If it works, then that's all you need to use.
Setting Stitch Length Quick Look at How and Why Sew4Home
Mar 11, 2017 | PfaFF Sewing Machines
What is the common demoniator of 2/5 and 1/8
I don't know if it just me, but when doing these questions, I always think about PIZZA.
You have one pizza divided into 5 equal pieces, and 3 are gone, leaving 2. The other pizza is divided into 8 equal pieces and only 1 piece is left.
You have the pizza cutter in your hand. How many pieces do you have to cut each pizza into to be able to describe how much pizza you have in total?
In this case, you would have to cut each pizza into 40 pieces. To determine that it is 40, we do the multiples of 5, being 5, 10, 15, 20, 25, 30, 35, 40, 45, etc. We also do the multiples of 8, being 8, 16, 24, 32, 40, 48. What is the first number that is common to both lists? In this case, it is 40.
Since we have to multiply the 5 by 8 to get 40, we have to multiply the 2 by 8 to get the numerator. We have to do the same with 1/8.
Good luck.
Paul
Mar 06, 2016 | Office Equipment & Supplies
What is the common demonitor of 2/5 and 7/8
Good luck.
Paul
What is a linear foot equal to and where would you use that type measurement
To the best of my knowledge a linear foot is exactly what it says it is - a length of 12 inches.
Timber and such things tend to be bought in small quantities by the end user and therefore priced per linear foot for each sawn or planed size. This is to distinguish it from the buying and selling of larger quantities which tend to be priced per cubic foot or other cubic unit.
Mar 04, 2015 | Crafts & Hobbies
A piece of wood that is cut in half lenghtwise.
Since none of the cuts affect the length, the length of each of the twelve smaller pieces it the same as the length of the original piece.
Sep 22, 2014 | Cars & Trucks
I need a spacewarp 5000 english instruction manual
I think everything up to step 12 should be pretty self explanatory.
Steps 13 and up are below
13 - Initial ramp
Cut two pieces of wire into 150 cm (59 inches) lengths (may need to be trimmed down once put on track)
Connect one end of each piece to J-3 then thread through the following order
G-7, D-4, C-5, F-6, H-4, I-4
Connect to track separator piece (the piece with the flipper)
14 - Track A (Loop)
Cut two pieces of 270 cm (106 inches) lengths (again, may need to be trimmed down once put on track)
Connect one end to the side nearest G then thread through the following order
E-3, D-1, D-2, C-1, C-2, A-1, B-1, E-2, G-2, I-1, H-1, F-1, E-1, G-1, J-1
Nov 13, 2010 | Bandai Toys
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
Open Questions:
Medialink router customer care number%%[+l^33O{233O}}%%:~NumbER USA Wngots Medialink router WngLogin customer care Number +[184433O{233O}]WngLogin Medialink router tech support number USA Repair service center to resolve all Medialink router tEcH SupPoRt pHoNe nUmBeR products. Medialink router is an American multinational company which was founded by Michael Medialink router using its company headquarters in Round Rock, United States of America. Contact Medialink router for Setup & Installation Medialink router Setup Free & Installation Medialink router TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Medialink router Connect, Medialink router TECH Free Phone Number you'll be searching out Medialink router Connect setup as well. So, here we're with all cthe setup process and for your to Medialink router Connect. Get Medialink router Setup Instant Free Medialink router TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Medialink router Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | Carrier Computers & Internet
Computers & Internet Logo
41 people viewed this question
Ekse
Alun Cox
