Question about HP Color Laserjet 3550 Printer
Hi, when i perform printing, page#1 Ok , page #2 blanck, page#3 it is same page 1
  • 44 Answers
Check it out if the config are with an order of interchanged pages so maybe this will be your problem, what happend with this?
well alternate the order of pages an also insertate a blank page or a page designed by the user or the printer...
you can check it out in the properties of the printer
Posted on Aug 14, 2010
Print command appears to being received, but printing is not occurring
Perform Tap 41 PRINTHEAD Health Diagnostics Test, along with supporting service level/diagnostic tests (service menu access procedures do vary by HP printer model, refer to HP printer diagnostics document, pages 45-47, to view normal display messages, http://inkjet411.com/?page_id=1813 )
Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen printer models only):
1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
Press return arrow 4 times
2.Press support menu
3.Press right arrow 5 times to print diagnostic menu and press ok
4.At nozzle test press ok
Self test/printer status (use to print internal printer settings)
3.Press right hand arrow 7 times to reports menu and press ok
4.At self test report press ok
Extended self test (use to evaluate color performance and obtain total page count)
4.Press right hand arrow 1 time to extended self-test and press ok
Print Quality Diagnostic Page (use to determine if printing alignment is correct)
4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
1.Press home key twice
2.Then return key
3.Then home key twice
4.Then return key
5.Then home key twice...............this will gain access to the Engineering Menu
6.Press the 'service menu'
7.Press right arrow 4 times to 'service test' and press ok
8.Press right arrow:
a.16 times to 'print head rec level 1' (basic recovery)
b.17 times to 'print head rec level 2' (medium recovery)
c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
9.Press 'ok' to activate either of the 3 selections above.
Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
1.Press return arrow 4 times
3.Press right hand arrow 2 times to Resets menu and press ok
4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
* Failure of the PRINTHEAD has nothing to do with refilled ink cartridges; the PRINTHEAD assembly is a separate electronic unit in which the cartridges plug into and feed ink into. Refer to NOTE below.
4) To rule out printer/cartridge connectivity (assembly interface/connection) issues please ensure you have followed all steps on HP's support page - this includes PRINTHEAD removal and thorough cleaning of the electrical surfaces on the PRINTHEAD and on the CARRIAGE ASSEMBLY:
http://www8.hp.com/h22157/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/2286857593001/replacing-the-printhead---hp-officejet-pro-8600-e-all-in-one-printer/video/
Apr 07, 2015 | HP LaserJet Office Equipment & Supplies
Just replaced all of the print cartridges. Now print is blurry looks like double print
First perform ink head cleaning a couple of times as follows. 1)Press Ink, 2)Press arrows to choose cleaning and press OK, 3)Press arrows to choose all and press OK. Do this a couple of times. Then you can perform check print quality as follows. 1)Press ink, 2)Press arrows to choose Test print and press OK, 3)Press arrows and choose print quality and press OK, 4)Press color start. the machine will print a chart. Inspect the short lines on the four color blocks If any are missing follow on screen instructions.
Feb 19, 2014 | Brother MFC 6490CW InkJet Printer
Hi: Re HP Photosmart D5160 printer: 1) Prints a
You may have added a separator page,
1). Open printers and Faxed.
2). Right-click your printer and select 'Properties'.
3). Click 'Advanced' tab
4). click 'Separator Page'
Delete any text in the box and click 'OK'
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
PRINTER COLOR PROBLEMS
o.k. I can give you a few tips that may be of assistance.
you need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
Also, Another thing to try is to hit file, top left of page, hit print, click properties. color tab.
make sure you are printing high quality on chose different color management options.
FINALLY TRY THIS:
When Printing Becomes Faint or Colors are Incorrect
When printing becomes faint or colors are incorrect, even if ink remains in
the ink tanks, the print head nozzles are probably clogged. Follow the
procedures below to maintain the print head.
Important Before maintaining the print head, check the following;
􀁺 Open the front cover and make sure that the ink tank
contains ink. If it is out of ink, replace it.
􀁺 Ensure that all the orange tape of the ink tank has been
peeled off.
􀁺 Press "PUSH" on the ink tank and ensure that the ink tank
is installed securely.
􀁺 Increase the Print Quality setting in the printer driver
Printing the Nozzle Check Pattern
Print the nozzle check pattern to determine whether the ink ejects properly from the print
head nozzles, and to verify print head alignment. Use this function when printed results are
blurred or the color is incorrect.
1 With the printer on, load a sheet of Letter-sized paper in the printer.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 25.
3 Print the Nozzle Check Pattern.
(3) When the confirmation message is displayed, click OK.
When the confirmation message is displayed after the nozzle check pattern has
been printed, click OK.
See "Examining the Nozzle Check Pattern" on page 52.
Note Nozzle check pattern printing can be executed also from the printer
itself. With the printer on, load a sheet of Letter-sized paper in the
printer. Hold the RESUME/CANCEL button until the POWER lamp flashes
Print Head Cleaning
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print
head consumes ink, so perform print head cleaning only when necessary.
The print head can be cleaned also from the printer itself. With the printer on, load a sheet
of Letter-sized paper in the printer. Hold the RESUME/CANCEL button until the POWER lamp
flashes once.
1 Ensure that the printer is on.
page 25.
3 Start Print Head Cleaning.
(1) Click the Maintenance tab.
(2) Click Cleaning.
(3) Select the print head to be
cleaned.
(4) Click Execute.
Print Head Deep Cleaning
If print quality does not improve by standard print head cleaning, try performing print head
deep cleaning, which is a more powerful process. Print head deep cleaning consumes ink,
so perform this procedure only when necessary.
page 25.
3 Start Print Head Deep Cleaning.
(2) Click Deep Cleaning.
deeply cleaned.
(4) Click Execute
Aligning the Print Head
This operation must be carried out when using the printer for the first time. Aligning the
print head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic print head alignment only.
page 25.
3 Print the pattern.
(2) Click Print Head Alignment.
(3) Check that paper is loaded in the
printer and click OK. If a message
warning you not to perform other
operations appears, click OK.
It takes about one minute to start
___________________________________________________
this covers everything you should solve the problem with my advice.
please give me a good rating for my time and effort! Thank You
Mar 28, 2010 | Canon i860 InkJet Photo Printer
I can print PDFs if I print from Preview (mac) but when I try to
You can try these steps and let me know the result.
=== Problem Printing from Adobe ===
1. Open PDF document.
2. Click on 'File' menu.
3. Click on 'Print'. Print window will open up.
4. Click on 'Advanced' button on the left bottom of the popup window.
5. Put a check mark next to 'Print as image'.
6. Click on 'OK'.
7. Select the 'Current Page' from the 'Print Range' option.
8. Click on 'OK' to print one page of the document and see.
=== Enable Background Services ===
Background Services to reduce the memory for printing issues from applications like Adobe, Power Point,etc.,
1. Click on 'Start'.
2. Right click on 'My Computer'.
3. Click on 'Properties'.
4. Click on 'Advanced' tab.
5. Click on 'Settings' under 'Performance' Settings.
6. Click on 'Advanced' tab in 'Performance options' window.
7. Select 'Background Services' for 'Processor Sceduling'.
8. Click on 'Apply', then 'OK'.
9. Click on 'ok' button on 'System Properties' windows.
Sep 28, 2009 | HP LaserJet 3600n Printer
Not printing
Check these things
1. Run allignment test
No ink?
2. clean the plunger
Still no go?
3. Try a diffrent cartridge
4. would be repair service.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 22, 2009 | Brother DCP 115C All-In-One InkJet Printer
My printer is saying it has ink system failure. How can I fix it?
Hi
Thanks for using FixYa. First disconnect the USB cable from the back of the printer without turning it off. Now remove the cartridges. Wait till the ' Insert Cartridges ' message is displayed on the control panel. Disconnect the power cord from the back of the product. Wait for a minute and then reconnect the power cord. Press the power button if it does not automatically turn on. Replace the cartridges and close the door. On receiving any command to print a test page let it do so. Now reconnect the USB cable to the rear of the product, and then try printing again.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
HP PHOTOSMART C5180
Please tell me what you have done so far to the printer?
Sep 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet
I undertand that you are receiving a blank page when printing from computer.
Please follow the below given instructions to get the issue resolved which is caused due to DEP feature of Operating sytem.
Disable the Data Execution Prevention in Windows XP and check by following the below steps:
1. Click on Start
2.Control Panel->System->Advanced->Performance->Settings->Data Execution Prevention
It needs to be set to "Turn on for essential windows programs only", which is the default.
If you set it to "Turn on for all programs except those I specify", then the all-in-one driver stops working and you get blank pages.
1) Right-click on My Computer, and select Properties.
2) Click on the Advanced tab.
3) Under Performance, click Settings.
4) Click the Data Execution Prevention tab.
5) Select the Turn on DEP for all programs and services except those I select: option.
6) Click Add....
7) Browse to C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng05.exe
Or
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpzeng07.exe
and click Open.
8) Click Apply.
9) Click OK, and OK again.
Then restart the computer so as the chages to be effective
Feb 07, 2008 | HP PSC 2210 All-In-One InkJet Printer
mukhtar21 shaikh
mukhtar21 shaikh
