Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 42in cut 19.5hp automatic trans craftsman when i press the clutch/brake to start then release to drive it cuts off also if i try to engage the blades it cuts off but if i lock the clutch/brake it stays running
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
The problem is in the seat safety switch or associated wiring. Lift the seat, find the switch, and take a look for a connector that is off, a broken wire, or a loose or broken mounting for the switch. If all that seems ok, remove the switch and put tape across the plunger so it is activated. Run the mower and see if the problem is solved. If not, replace the switch - it's not expensive. Parts are available from Sears online or at their stores. You'll need the model number of your tractor. Good luck! Please rate my solution if helpful.
Posted on Aug 01, 2010
When shift lever is moved ouut of neutral mower takes off without using brake/clutch pedal pressing that pedal does no good craftsman 24 hp 42 inch cut
this should never happen. sounds like the belt is too tight as the pressing of the pedal should engage the drive train. Look for an adjustment being out or possibly a broken retractor spring. Be sure to pull spark plug wire while trouble shooting as you do not want to have the engine start.
Aug 01, 2017 | Craftsman Garden
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts and runs, blades turn but will not move, what could be the problem?
the blades and the trans use 2 different belts also is it a automatic drive and the release lever that you pull out to push it?
Apr 05, 2012 | Craftsman Garden
I have a Craftsman 19.5hp 42in deck lawn tractor problem. The tractor starts ok but when I release the brake it shut down.
Your tractor has several safety switches. Look around your brake pedal and linkages. You will see a little plastic switch has 2 wires going to it unplug and put the 2 wires together if it runs switch is bad. You can replace the switch or just cut the wires and wire nut them together.
Sep 28, 2010 | Craftsman Garden
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
166 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
