Question about Vacuums
My belt broke. I have a replacement. I dont know how to install the replacement belt.
There's a plastic cover over the agitator. (the part that should spin, with tough bristles)
Unscrew it. Pull out the agitator. Put the new belt over the 'spinner' (the part that's connected to the motor) and the special pafrt of the agitator. Snap the agitator back into place, making sure it's secure on both sides.
Screw back on the plastic cover.
Wallah!
Posted on Apr 25, 2008
Bissell quicksteamer 1950 motor
take bottom apart see if belt broke if bad check motor shaft see if it spins
Jul 31, 2017 | Bissell 1960-3 QuickSteamer Plus Upright...
The belt broke. Is is possible to install a new belt and to get replacement part?
Yes you can bye belts from any electrical store and the don't have to be bran names dysons are very easy to replace!!
Jan 17, 2011 | Vacuums
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
Vacuum brush roller wont turn
You dont say if you checked if the belt is still whole so my guess is the belt broke(it could've fallen off and not be there at all but you definately need a belt) check that and let us know
May 17, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The belt keeps breaking lately. I've had the
Before putting on the new belt make sure the brush turns freely and nothing is wraped around the bearing ends, if it is not turning free and is clean try a little grease or vasaline on the bearing ends. dont get any on the belt though. check the motor shaft also it should be clean and no residue from the old belts on it. it can be cleaned with rubbing alcohol and a rag, if really caked try a scotch pad .
Oct 24, 2009 | Kenmore Vacuums
Moter belt
You can find the manual for your vacuum by clicking on this link: http://www.bissell.com/images/UserGuides/1697_207.pdf
May 05, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
How to replace a belt successfully on a Bissel Powrforce 3522?
How do I replace the belt? I don't know how to get into that area.
May 21, 2008 | Bissell 3522 PowerForce Bagged Upright...
I want to install a belt on the turbo power 2000 upright vacum cleaner , What do I have to do to install it. The old belt broke.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564997
Generic problem for all Vacuums
I want to install a
Posted by mcpo on May 02, 2008
I want to install a belt on the turbo power 2000 upright vacuum cleaner , What do I have to do to install it. The old belt broke.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are only 2 ways you can install a belt on a Turbo Power 2000, either you can remove the bottom plate and expose the belt, 1st place the belt on the brushroll section of the vacuum then use a belt puller or a screwdriver with a left or right hook @ the end and pull the belt onto the motor pulley, once you get the flat belt onto the motor pulley than you do what is called tracking to straighten belt out so it runs straight, replace the bottom plate. 2nd then remove the top cover by 2 to 4 screws or levers and then remove the top, then follow the procedure listed above. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
D.d vaccum
Did you check the brush roll, if the ends aren't turning freely, then it needs to be replaced also.
Mar 20, 2008 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
81 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
