Question about Brother XL-2600
I have gone over the threading of the machine several times and still I cannot get the bottom thread not to loop. Tried the setting dials. I can get the top stitch to look correct, but the bottom is a mess. When placing the bobbin, I do place the thread underneath the gray piece and have a tail sticking out when I but the plate back on. I have the needle go down and it catches the thread. The bobbin thread is then going directly from the bobbin through the sewing port. Is that correct? That is the only thing that I can think that is not right.
  • 255 Answers
Actually, it sounds like your upper tension is too loose. If the upper tension is too loose, it won't pull the bobbin thread up into the fabric properly. Check out my suggestions on Adjusting Tension and see if that helps.
Robbie
Posted on Aug 02, 2010
kent581
  • 87 Answers
SOURCE: no bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Posted on Mar 18, 2009
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
  • 1116 Answers
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Posted on Mar 10, 2010
SOURCE: Kenmore sewing machine #16227 needle thread making
It is most likely because you have it on a type of stitch but did not switch the didstance that you want the zig zag to be. Just change you stitch or your distance.
Posted on Feb 10, 2011
  • 99 Answers
SOURCE: now that the needle catches
I had the same problem and ended up taking the machine to a small repair shop. there is a critical timing isue between the top cam and the bobbin, the man did a 5 minute repair and it has worked great eversince. It is a little tricky to setup so I would not try to do it myself.
Posted on May 04, 2011
I am a new sewer have a Brither BM-2600 what numbers on the dial do I have for just plain stitching I have tried lots of combinations but the cotton underneath is all bunching up and not sewing right
I am not sure as to your machine, are you saying a "brother" machine? If your tension is set, say on 6 and it is too tight, turn the dial one more number......to a 7 or to a five and then check again. Also, I would rethread the machine and also take the bobbin out and then put it back into the machine. A lot of times, the bobbin isn't threaded into the machine correctly and it bunches up. Also, you can't use certain thick thread on some machines.
Jun 05, 2017 | Sewing Machines
Bottom thread seems too tight!!! Help!!!
If the bottom thread is tight there should also be loops on top and this means that the upper tension is too tight.
Get out your manual (http://www.singerco.com/uploads/download/1198_8763-efs.pdf) and turn to page 24. Under "ADJUSTING TOP THREAD TENSION" it tells you that if you're having thread tension issues, change the tension control dial on the top of your machine from auto. It also shows you a diagram with your problem illustrated on the right side of the page. The bobbin tension is set at the factory, so all tension problems can be solved with top tension adjustment. Set it manually and if it loops on top, loosen the tension a little. Test again. Repeat until loops are gone.
Using different colours on top and bobbin and a contrasting fabric (e.g. black top, white bottom, light blue fabric) means you can easily see what's happening. A perfect stitch is when you see exactly the same stitch pattern on both sides of the fabric. On top, the bobbin thread colour appears between stitches as a tiny dot and on the bottom, you see the top thread dot between stitches.
If it's impossible to get the tension right, take it to a technician, because it's a sign that the hook timing needs attention.
Apr 21, 2015 | Singer 8763 Curvy
Sewng machine fails to loop on bottom bobbin
There are several possible causes for this problem.
Simplest first.
1) The machine has sat in the closet for three or more months, and the oil has ceased. The fine oil requried for these precision machines does run away, and/or cease up into a grease like paste, causing the parts that move in precise harmony, to be not so precise.
The cure for this, is to remove all thread and fabric, and run the machine full speed for about two to five minutes. This heats up the parts and loosens up ceased parts. A good re application of fresh oil helps too.
NOTE: Check the needle is Straight by turning the machine a couple of turns by hand and seeing that the needle dosn't hit any metal parts. A breaking needle can cause dammage to the machine or user in when operating at high speeds.
2) Tension dials have been knocked out of balance. There is a numbered tension dial on the front of the machine, somewhere along the threads path from spool to needle. if this is too tight, the thread will not leave a loop big enough to catch the bottom thread. Be sure this is set to about 3, usually. It should be adjusted while stitching, when you get to that point.
On the bottom thread, on the Bobbin Holder piece that comes out of the bottom, there is a small screw that adjusts tention of the thread comming out. This screw should not be tight, but tight enough. Completely by tactile intuition, this screw should be adjusted to allow the thread to slide out of the bobbin holder smoothly. It must have some tension to pull the thread from it, but not so much that it is noticeable, or take much of a grip on the thread to pull it out. (difficult to describe)
These two tensioners must balance so the threads, cross paths, but also pull the stitched snugly into the fabric being sewed.
3) Bent Needle, this is a problem if the fabric being sewed has pulled the needle off it's center. If it is not perfectly straight, don't use it.
4) Cheap thread can be a problem. If the thread is frayed, or fuzzy looking, it may be that it will not work with as fine a needle you are using. Needles have various sizes and sized holes to feed the thread through, a fine needle needs fine thread, and coarse thread needs a larger needle.
These are the primary causes of the threads not looping together properly. I hope this helps.
Jul 24, 2014 | Euro-Pro Fast and Easy 420 Mechanical...
The bottom thread of stitch loops severly. I have checked and rethreaded, change dtop and bottom tension till the cows come home and nothing I've tried makes a difference.
if you are getting loops on the side its from the top thread not being tensioned enough to hold it firm as the needle goes down through the fabric. Either top tension device is broken or its gunked up with fluff or dye particles. If you can access the tension discs to clean them, then try this first. Turn top tension to zero, then "Floss" betwen the discs with the selvage edge of a clean piece of waste cotton fabric - if it comes out with black gunk on the edge, then do it again until it is clean. You can moisten the fabric edge with some denatured alcohol to aid cleaning if it seems really gunked up. Black and dark coloured threads often shed dye particles, and cheap thread will be quite "hairy" this adds to the gunk. Its a good idea to clean the tension discs out regularly, along with cleaning the bobbin area and oiling the designated oiling points (although many new machines now have oiling wicks for the technician, and may not have marked points for you to oil. However cleaning is still very important if this is your type of machine. Textile fibres absorb oil, and ultimately "felts" up into a lump that affects performance of the moving parts.
Once you have cleaned it, turn dial back to 4 or 5, normal setting, then thread up from spool to just above the needle with the presser foot raised, then lower presser foot and tug downwards on the thread; it should be firm to pull. If this is still not happening, take it for a service, the spring in the tension device may have broken.
Nov 27, 2011 | Singer 3116 Simple
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
Thread looping on top and bottom of fabric
hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,c978815.jpgthis just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winder5a00a72.jpgfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
Apr 14, 2009 | Brother XL-3510 Mechanical Sewing Machine
Can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
Mar 15, 2009 | White Sewing Mighty Mender WW100...
March 12, 2009 kenmore 385.17922 sewing machine ***this site won't let me ask a question - because it doesn't have this sewing machine in it's PRODUCT LIST...but i'd still like to ask the questions, and...
Dear VeeVeeV,
when I've had that problem it was due to incorrect threading of the top thread. Sometimes it "jumps" out of one of the thread guides, particularly the round one with the tension spring. The bottom thread looping & the machine not sewing is my first clue sometimes that it's done that. good luck, Georgia
Mar 12, 2009 | Singer 3116 Simple
WHITE 2037 TENSION ISSUE...
Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
General rule of thumb..
Loops on the bottom-- problem on the top
loops on the top--- problem on the bottom.
Hope this helps..
Mimi
Dec 15, 2008 | White Sewing 2037 Mechanical Sewing...
Brother XL-2600 Logo
298 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
