Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
The top rack dishes are not getting clean. the spra arm is clear and the tube supplying water to the arm is clean. the float is also moving freely.
    President:
  • 2,468 Answers
Does this have the water conduit tube going up the inside of the rear wall where you can see it,if so,the conduit "horn" where it connects to the tube that feeds water to the upper arm with repeatedly opening and closing this horn wears out and lets water get past here and lowers water pressure to the upper arm
Posted on Aug 01, 2010
  • kdavis992 May 09, 2011
    what do I do to fix this? Please tell me what parts I ned or what.
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 15, 2012 | Kenmore Dishwashers
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
Dish washer not cleaning dishes in top rack
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Top rack of dishes no getting cleaned checked water tube to top rack its clear
there is a chance that the main washer motor is not supplying enough water to the upper spary arm.the possibilty that there is not enough water in the bottom of the unit during the time it fills up would cause this problem check your water pressure.if this is good then the main wash motor may need to be change
Sep 16, 2009 | Dishwashers
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Kenmore dishwasher not cleaning
Growand:
There is a rubber tube which supplies water to the top spray arms. That is, If yours has top spray arms. This rubber tube has to make a connection when one slides the top rack back in. That tube will rot after a while, check it out.
If the soap is not being used up, reduce the amount of soap you are using and run the dishwasher empty with a pie plate sitting on the bottom rack with a cup of distilled (cheap) vinegar in it. Run it hot and long, recheck and redo if neccessary.
Jul 30, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
553 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
