Question about LG WM-2277HW Front Load Washer
Walking Washer I have had a LG front loader washing machine for about a year and a half. During spin cycle the washer moves forward several inches. The repaid person came and leveled and checked the internal leveling. The washer is still trying to walk out of the laundry room.
  • 3 more comments
  • Anonymous Apr 27, 2008
    We have the same problem.  Putting a rough pad under has not worked!
  • JHFERRER May 12, 2008
    MY LG WASHER IS SITTING ON IT'S PEDESTAL AND WHEN SPIN CYCLE BEGINS IT VIBRATES FRANTICALLY AND STARTS TO INCH AROUND THE LAUNDRY ROOM
  • boscoandtia May 16, 2008
    I have WD-1274HB LG front loader. It is located on the 3rd floor near the bedrooms. When it spins the whole house shakes and the neighbours are complaining. Even though the service man came to check, he said it is normal. I find that hard to believe. Can you help?
    Thanks
    Victoria
  • Nifty2 Aug 22, 2008
    I had the same problem on an LG Front Load Washer. I installed 4 rubber blocks available at "Best Buy" or other merchants. The name of the product is "Shake Away" Plus vibration Isolation Pads and cost around $30.00. The rubber blocks are placed under each foot of the washer between the washer and the floor. This soultion made a 100% improvement.
    JC Lake Tahoe, Ca.
  • Anonymous Apr 29, 2009
    The washer vibrates and bounces around during spin cycle. It is not a leveling problem, its a problem with the machine.
Same problem--so much so that my downstairs kitchen FLOODED the first time I used the LG washer (it walked off the platform and fell forward, somehow the door opened just enough to let out LOTS of water). My husband easily fixed it by placing a thick rubber pad under the washer, in addition to leveling it. It is not bolted down to his "homemade" platform, but he has reinforced the platform to such a degree that it is sturdier than the platform drawers sold by the company and sturdier than our 100 year old wood floor. Not a problem since--it is the machine I always wanted--quiet, efficient, NO vibration at all now, works perfectly in our upstairs bathroom.
Posted on Aug 20, 2008
  • 489 Answers
The best way to fix this problem is to adjust the front legs while the machine is spinning a full wash load.  Put in a load of clothes and run the machine to get the clothes nice and wet.  It will take about 5 minutes to get them completely wet.  Next, turn the washer off.  Now, turn the washer back on and push the spin button to select the extra fast speed.  You washer will go into a drain mode and then begin to toss the load into a balance spin mode.  Once the washer is spinning the clothes, check the balance of the unit by pushing the front left corner of the washer towards the right rear corner and right front corner towards the left rear corner.  If the sound of the washer quiets down on one side vs the other side, adjust the front leg to quiet that side.  Do not attempt to adjust the rear legs as they do not require adjustments at all.  Everything adjusts on the front legs.
This procedure works if the floor is sturdy enough.  If the floor is old and the wood is weak, it will not work.
Posted on Apr 27, 2008
    Genius:
  • 1,028 Answers
Due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Posted on Apr 25, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
LE error code during wash cycle (washer full of soapy water). Washer does nothing now (no spin etc). Any ideas?
having the same problem - means load is too heavy so take stuff out then try to re-run it. I read some time ago that this eventually happens with front-loaders - they can't handle the weight - I had less than half a load in there and had to take stuff out. Time to have it serviced but still usuable with only a few pieces of cloathing.
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Rocks and bounces during spin cycles
You don't state what type and model of washer you have but following is the Whirlpool service manual for top load direct drive washers.
Check the sections on the base and suspension springs and pads.
If one or more of these is not connected, or the pads are damaged, the washer will vibrate during the spin mode.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 22, 2009 | Washing Machines
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moving
Don't know if you've done it, but put a level on the machine itself and make sure it is level. Adjust it front, back and side to side. This may cure your "walking problem".
Jan 28, 2008 | LG WM-2277HW Front Load Washer
Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Jan 12, 2008 | LG WM2277H Front Load Washer
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
722 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
