Question about Winbook Corporation WinBook A710 (618996100026) PC Notebook
Laptop beeps then shuts down even when plugged in
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
Can't boot system shuts down immediately
The hard drive has failed and needs replacement.
Feb 23, 2014 | Acer Aspire 5742Z-4200 Notebook
NEC Versa p8210 Laptop Power Shut down fault
The beeping ounds like overheating, assume you cleaned out the laptop cpu fan and heat sink when you had it apart?
The shorting issue that you refer to, indicates that there is an internal fault in the circuit that carries the DC power to the board. I would dismantle the laptop and try to power it on on an insulated bench, to see if you can spot any arcing as the Adaptor is plugged in. Check the board and look for the inline ceramic fuse, use a multimeter set to the OHMS scale and test the integrity of the fuse to see if it is carrying a current (battery out and unplugged from mains obviously). Then look to see if there are any blown or burned capacitors and resistors on the board or any burned circuit traces.
Also try a different adaptor and check the output voltage of the old one
Jun 21, 2012 | Computers & Internet
Laptop shuts down automatically and emits a beeping sound
Yes this is for the memory problem...Try to change the RAM...
Oct 20, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
Compac laptop nc6000 tries to start up then shuts
For all troubleshooting, make sure the laptop is connected to the DC power cable rather than running off the battery.
are you getting any beeps? if not, it's probably bad system board or cpu. if you are getting beeps, then that beep code will usually give a clue as to the failing hardware.
Oct 03, 2009 | Computers & Internet
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
I get 2 beeps and thats it
We have a dell laptop that does something similar. try pulling out battery and plugging into the wall outlet. turn on computer and wait for it to totally start upthen plug in battery. this works for me.
Jan 24, 2009 | HP Compaq Presario V2000 Notebook
Beeping then shuts down.
Hi Speedport!
This isn't something as simple as a dead / broken / malfuctioning battery is it ? Try removing your battery, plugging the laptop into the mains and running it idle. The Bios update you found may have been a coincedence...
David
Nov 19, 2008 | Toshiba Satellite A205-S4617 Notebook
Laptop beeped once as it shut down
Ya its a computer they are built to fail =). 1 beep is usually a normal sign. when you start hearing more then 1 beep then I might worry.
If you found this helpful I hope you will rate accordingly. If you have anything else ever in the future you can use the ask me feature at
www.fixya.com/users/leethedeuce
Thanks,
Lee
Jun 21, 2008 | Toshiba Satellite A135 Notebook
Winbook Corporation WinBook A710 (618996100026) PC Notebook Logo
438 people viewed this question
Top Winbook Corporation Computers & Internet Experts
Masood Rasool
Level 1 Expert
Mike Rommel
Mike Rommel
Are you a Winbook Corporation Computer and Internet Expert? Answer questions, earn points and help others
