Question about Canon Powershot PRO 1 Digital Camera
Powershot Pro 1. The camera overexposes images. All pictures taken in moderate to bright sunlight comes out white. Detail completely blown out. However, no problem when the flash is used. The flash also pops up in all situations. Even when light is good.
jackboy
  • 2985 Answers
SOURCE: Incorrect Light Meter
Make sure you have correctly set the Iso/ASA factor correctly and the flash is switched off Check out the Full manual which is a PDF file on the CD
Posted on Aug 05, 2007
  • 4 Answers
SOURCE: Canon Powershot Pro1
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Posted on Nov 27, 2008
ixinatheixi
  • 8 Answers
SOURCE: photos taken outside are too bright
turn down your exposure.
or your cam may be set to night mode
so it lets more light in.
Take it off and it should be alright
x
Posted on Jan 08, 2009
zohail
  • 1223 Answers
SOURCE: Image extremely overexposed and has horizontal banding
CCD failure !
but u are lucky canon is repairing it free of cost just see the link just call them they tell u how to send ur camera dont worry if u are not on list just call them
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Posted on Apr 09, 2009
  • 161 Answers
SOURCE: Canon Powershot A460 gets overexposed pictures
Change the exposure/ISO through settings.
This is the cause for over exposed images.
Posted on Sep 10, 2009
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture...
The shutter flex cable inside the lens is broken. Happens to all cameras from Canon A4xx series. At day the images will be overexposed with horizontal lines on it, but it could look better at dark / night. The FLEX has to be replaced. Canon doesn't supply new flex cables for these, but there are some cheap copies on ebay. But as these brake very often, I wouldn't suggest you investing money in this camera, because it will brake again sooner or later.
Jan 26, 2011 | Canon PowerShot A470 Digital Camera
After taking a photo, the picture is just a white screen. a camera shop sugested the white balance was faulty.
It's not a problem with the white balance. Is the picture completely white or just overexposed? If completely white, it has to be a problem with the imager (CCD) or the board itself. I have seen some of these with faulty imagers, but the problem is that Canon (at least in some European countries) won't supply these imagers. They replace the whole camera.
Jan 24, 2011 | Canon PowerShot A480 Digital Camera
When viewing images on the LCD display ,pictures with White or bright parts to the image the display flashes between White and black is this a setting issue .the camera is a Dx 40x
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all detail. This is generally considered a bad thing and so the camera is warning you of that. Of course, the camera doesn't know what kind of effect you're trying for and thus it's just a warning. The correct fix in most cases is to use exposure compensation to reduce the exposure and bring back the details. This risks losing details in the shadows as they go pure black but that's not considered as bad. After all, we don't really expect to see much detail in the dark.
That was the long answer. The short answer is, repeatedly press up/down on the multiselector to cycle through the different views of your pictures.
Dec 18, 2010 | Nikon Cameras
On my Nikon D70s, when I take a picture and see the image previewed briefly on the back LCD, the highlights flash negative image tones(black) in about 1/2 second intervals. This same effect is also present...
There is nothing wrong with your camera. What you are seeing are the blown-out highlights. Those are the portions of your image that have been overexposed so completely that they have lost all detail and will show up as pure white. In most cases the proper fix is to reduce exposure to bring back the detail.
If you simply don't want to see the "blinkies", press up/down on the multiselector repeatedly to cycle through the different views of your images.
May 16, 2010 | Nikon D70s Digital Camera
How do you remove the white areas of a shot from flashing black when you look at the image?
What you're seeing is blown-out highlights. These are areas of your picture where the bright stuff (highlights) have been so overexposed (blown-out) that all detail has been lost. That's not necessarily a bad thing, but usually is. The proper fix is to reduce exposure slightly. Lost details in the dark areas are usually considered more acceptable than lost details in the bright areas.
If you simply don't want to see the blinking black/white parts of your picture, simply press up/down on the multiselector to select a different view of your picture.
Apr 25, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
We have a canon powershot A410 digital camera with 3.2 mega pixels (purchased brand new in fall 2007) and recently, whenever we take pictures outside, they come out completely white (overexposed). The...
Hi there its a chance of sersor damaged. He not able to read the light. Thats why outside image are over exposed. I suggest you visit service center for check or repair the lens sensor.Thanks.
Apr 07, 2010 | Canon PowerShot A410 Digital Camera
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Overexposure
I bought a white filter on eBay, popped this on the end of the lens, set my white balance and HEY PRESTO... exposure is perfect now.
May 06, 2009 | Sigma 18-200mm f/3.5-6.3 for Nikon
Bright white exposure
This may be a ccd problem.
See this link.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Aug 06, 2008 | Canon PowerShot A80 Digital Camera
Canon Powershot PRO 1 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
