I have a Sony FD Trinitron Wega(Model # KV-36FV26) that has a blinking standby light that blinks intermitenly. Does that mean that trouble is soon to come?
THE TUBE COULD BE GETTING WEAK . IF YOU GIVE
ME THE BLINKING I COULD TELL YOU BETTER, IT ALSO COULD BE A SIGN POWER SUPPLY IS GOING .BOTH PROBLEMS CAN BE FIXED I WOULD WAIT FOR TV TO GO OUT BEFORE FIXING INTERMITTING PROBLEMS ARE HARD TO FIX ESTIMATE ON REPAIR IS AROUND 160,00 DOLLARS
THANKS DOCTOR VIDEO
Posted on Apr 25, 2008
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony FD Trinitron WEGA KV-27FS120 the Standby light flashes four consecutive times with a pause in between sequences. When I turn the TV on with the remote, it powers up, you have volume but no...
It is vertical deflection failure problem.
Let me know if you want to repair TV by yourself, that requires soldering parts in PCB experience.
Aug 08, 2009 | Televison & Video
Sony on stand by with 7 blink intervals
depends on the repair, Light bulb can be 50-150 dollars so it might be fair.
Jul 03, 2009 | Sony Televison & Video
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
My Sony Trinitron Wega television set has problems turning on.
The standby light should be blinking a code. That along with the model number will indicate the problem circuit that prevents the set from turning on. Also, with that info, we can provide you with the probable cause and solutions.
Please update this with the model number and the blink count.
Thanks,
Dan
Dec 12, 2008 | Televison & Video
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Jul 10, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
