Question about Kenwood KDC-M9021 CD Player
Hi, my kenwood kdc m9021 has just stopped working even when i press the reset button it does nothing apart from going into the cd eject sequance and then stopping with the face flat and it looks like there is no power to the screen.Can you help pls?
SOURCE: Kenwood KDC-X711 not working
Got the same problem, try taking it out and throwing it on the ground a couple of times.
Posted on Apr 24, 2008
shagone
  • 34 Answers
SOURCE: Cannot remember my security code after reset Kenwood kdc-mp435u
Try code KCAR entered from the remote. 3 entry methods are detailed below.
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: Kenwood KDC-MP438U "USB ERROR"
IF YOU DID NOT PRESS THE RESET BUTTON NEX TO THE USB PLUG, DO IT. IT WILL REINITIATE THE DEVICE TO THE FACTORY; YOU WILL HAVE TO ADJUST THE CLOCK.
I DID BECAUSE IT WAS WORKING AT FIRST.( PAGE 3 OF THE MANUAL)
CLAUDE
Posted on Jan 19, 2009
SOURCE: Kenwood KDC-X492 where is the reset button????
if you have the excelon
then its in between the aux input and usb interface
Posted on Jan 28, 2009
SOURCE: Kenwood KDC-C717 - E-99 error
There is probably a jammed disc or disc holder. It cant eject the cartridge because the unit cant put the disc back into the cartridge to the left.
Took me a about 20 mins gentle persuasion after removing the plastic front (carefully depress the little plastic clips on the edges and (again, gently, lever the front off) and removing the metal case - half a dozen screws each side and remove the bottom. The top stays fixed to the workings. I could then get into the gap between the top case and workings but be careful not to pull the unit from the rubber antishock mountings etc. and remove the problem disc.
I removed the plastic fascia which surrounds the magazine hole too, not sure if it was necessary..!
Again - be careful not to be rough with it, you dont want to snap the plastic clips, etc and also check the horizontal/vertical adjusters are back on in the correct position if they come off.
Posted on May 16, 2009
What sequance of buttons do i press to enter the radio code
it goes off of the presets so if you have to push 1 but 1 and 2 share the same button just press 1 and 2
Aug 22, 2010 | Kenwood KDC-334SA CD Player
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Nov 18, 2009 | Kenwood KDC-516S CD Player
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
CLAUDE
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
CD won't eject
If it brand new take it back to were it ws purchased to have it replaced.
Nov 12, 2008 | Kenwood KDC-MP4028 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-M9021 CD Player Logo
55 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
