It will not come on at all.Worxed fine yesterday,checked all outlets...all are fine.The remote will not do it or the switch on yhe side.It is about 2 yrs. old
  • 10,594 Answers
I wan to know model number and brand of your tv to diagnose possible cause of problem.
Without model and brand info, it is difficult to determine what kind of tv is this.
Thanks.
Posted on Aug 01, 2010
  • 10 more comments
  • swd08a Aug 01, 2010
    model no.50pfp5332D/37-serial no. ya1a0740007106
    and it is a phillips
  • Shahid Electronics
    Shahid Electronics Aug 01, 2010
    Does power indicator lit when tv plugged in outlet?
    No,nothing happens,and like i said yesterday it came on fine with the remote
    OK, Power supply board seems got some problem and causing no power.
    Replace power supply board to fix your tv. Local tv repair shop will help you if you have no experience of fixing electronics stuff.
    Do u know how much one cost?
    Power supply board is available with Shop Jimmy for $100 plus labor to replace it.
    Thanks.
    Hey, i do not have a board that looks like the one in that link in my t.v...... there are a couple of boards with Samsung on them!!!!
    OK, please recheck model number of tv, I gave you power board info as per given model number.
    Click HERE to see all boards related with Philips model 50pfp5332D/37 and can you please post image of your power supply board here?
    I did 50PFP5332D/37,it wasuilt in Mexico
    OK, then check part number written on board in your tv and search if it is available in part shops.
Lenovo tower will not power up. Everything else on same power strip is working. Monitor, copier etc. I tried unplugging it and using a different outlet but still nothing. It was working fine yesterday...
If you tried a differwnt outlet in the strip I would take the tower or power supply out and have it tested at a repair shop. I am leaning towards a power supply fault, but I
have also seen where one of yhe outlets in a strip burns out. Sometimes the power supply has a green light near the power cord. If this is out then it will need replacing.
Dec 05, 2017 | Lenovo Computers & Internet
2001 chevy malibu only starts by remote
probably where the remote start wire was taped into the starter wire got broken and now the key side isn't attached to starter anymore. Id check the starter relay and fuse before anything
Mar 17, 2013 | 2001 Chevrolet Malibu
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
My vacuum worked fine yesterday and now doesn't start
To my knowledge, the on/off switch is the only area to turn your vacuum on or off. There might be a problem with your cord, or with the switch itself. I suggest checking for clogs and anything that may cause a problem.
I also suggest taking it to a local vacuum shop to have it looked and as you may need some new parts (cord/switch)
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
No power..worked fine yesterday
HI
3 things
1. You power filter is bad and needs to be replaced.
2. Your board is bad and you need to replace it.
3. If your lucky there is a fuse on the back side of the boiler and it is blown.
Jan 06, 2010 | Starbucks Saeco Italia Digital Barista...
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
New Single Feed switch/outlet not working
Hi there, first what is your porous for the device? Do you want the switch to feed the outlet or do you want the switch to be independent? (switch feed outlet)---- black feed to gold screw on switch. then from lower screw on same side to outlet (this should be black also)> remembering to tie neutrals with wire nut in rear with pig tale to switch. hope this helps.
Mar 21, 2009 | Electrical Supplies
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
