Question about Toshiba Satellite P205D-S8804 Laptop
Bios Faile during bios update dead and no eny activity only power LED on,i try to flash the bios by crisis recovery disk creator with 3 diffrent bios version but no effected please help me!!!!
  • 700 Answers
Bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Posted on Aug 01, 2010
Hi my laptop is model vr320 with intel t2080 dual core cpu 1.78 ghz, integerated radeon express 200m video 1 gb 667 mhz memory and 80 gb harddrive, i have been getting a message - (non compliant acpi bios)...
You shoud use Crisis Disk Recovery Creator to reload your BIOS. First search on net the BIOS file, it should be max. 1Mb syze and download it, it must be in .wph format. Download Crisis disk program, ver. 3 or 4 that supports USB memory cards, max. 4Gb. Copy the BIOS file in the crisis folder and rename it as BIOS.wph. Click on wincris.exe, select your USB device, it will create your Crisis disk on it. Your USB will be formated. Then, disconnect the battery from your laptop and the AC cable, insert USB card, press Fn+Esc and keep it pressed, connect the AC, wait 10 secs, power on the laptop, after 5-10 secs you can hear some beeps, then release Fn+Esc and wait 5 minutes. The laptop should restart completely functional.
May 15, 2011 | Intel Motherboard
Hi i need a expert to resolve my laptop Acer Aspire 1640z . I was upgrading my bios from 3a19 to 3A24 and now... after powering on, i hear 1 long beep and 2 short beeps and my screen is black. Nothing...
According to my troubleshooting manual of Acer Aspire 4520-Z3 about
BIOS Flash Utility:
The BIOS flash memory update is required for the following conditions:
New versions of system programs
New features or options
Restore a BIOS when it becomes corrupted.
Use the Phlash utility to update the system BIOS flash ROM.
NOTE:
If you do not have a crisis recovery diskette at hand, then you should
create a Crisis Recovery Diskette before you use the Phlash utility.
Do not install memory-related drivers (XMS, EMS, DPMI) when you use the Phlash.
Please use the AC adaptor power supply when you run the Phlash utility.
If the battery pack does not contain enough power to finish BIOS flash,
you may not boot the system because the BIOS is not completely loaded.
Follow the steps below to run the Phlash.
1. Prepare a bootable diskette.
2. Copy the flash utilities to the bootable diskette.
3. Then boot the system from the bootable diskette.
The flash utility has auto-execution function.
You need to prepare a bootable Flashdisk into dos mode
then you should search for the above mentioned crisis recovery
diskett and transfer its content to the flashdisk.
I read from another forum that for recovery of Aspire 4520 problem
can be done through pressing of the keys combination as follows:
press FN + ESC and hold them, then just hit the power on button
and release it, after awhile "the power button" should blink red,
release the keys FN+ESC and don't touch anything.
After successful of recover the bios it should restart normally.
That happen after 20-30 minutes. If it doesn't restart just repeat the
process.
Hope it helps
Mar 09, 2011 | Computers & Internet
Only a black screen, no indicator lights are nurning
I am using an Acer and it happened to me thrice. It is an easy fix.
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again. Good Luck
Jan 24, 2011 | Acer Aspire One PC Notebook
I tried to upgrade the bios of my lenevo g460 but it failed and now it does not open only led flashes and hard disk led keeps on blinking
Hi
I'm not sure is BIOS Crisis recovery will work on your laptop but you may as well give it a try.
Turn the laptop off and hold Win-B or Fn-B as you start the laptop up.
There is also Lenovo Onekey Recovery which may help, you can download it here >>>>>
http://lenovo-onekey-recovery.software.informer.com/
Good luck and regards
Dec 14, 2010 | Lenovo G460 Laptop Computer 06774CU Intel...
Hi, my acer aspire one though is on, its screen "dead"
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 04, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Cant enter bios menu
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
Download the latest BIOS, extract all files from the zip file, put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If it doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again. BIOSeven if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
if that doesn't work the link below sells help http://www.badflash.com/
Mar 13, 2010 | Computers & Internet
No display
Hope you have tried F5. Also try to update the BIOS via the crisis disk.I think the crisis disk program is on the recovery cd you got with your acer one. if not it's available for download at the acer website.
Thanks for contacting Fixya.
Nov 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer 5920 Laptop bios problem
it is not possible from crisis recovery disk.You must replace *********** board
Jun 25, 2009 | Acer Aspire 5920-6727 Notebook
I was trying to go through recovery thinking I could get more speed on laptop and I messed comp. up. Only get a blank black screen. tried powering down, rebooting, still can't get on. Help!! i was trying...
Flashing the Bios is a LAST DITCH effort to resolve Hardware issues. You should NEVER flash the bios unless you are absolutely certain it's the correct bios for your computer, also NEVER flash bios from within windows..
There may however be a solution for you, Acer laptop computers with the Pheonix BIOS sometimes has a " flashback" feature, allowing you to revert to your original Bios..
You will need to contact Acer to get a Crisis Bios recovery disk from them. Or ask for further information on how exactly to recover from a bad bios flash.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
Toshiba Satellite P205D-S8804 Laptop Logo
432 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
