Question about Dell 924 All-in-One InkJet Printer
Printer error 0x0000070c, Windows 7 Ultimate x86, HP LJ 1022
Soulvisitor
  • 1113 Answers
SOURCE: HP 1020/1022 PRINTER OFFLINE
No drivers / Incorrect driver setup on user pc
Posted on Oct 19, 2007
SOURCE: HP 2430tn lj printer with 13.20 jam inside top cover error
This question is directed at Steve from the post above. I need to order the sensor you mentioned. Is that sensor located exclusively on the power supply (Part number RM1-1505-000CN)? Will I need to order the whole power supply, or can I order the sensor separately? It does not show it very clearly in the service and maintenance manual. Thanks for the help!
-Shawn
Posted on Nov 14, 2008
  • 412 Answers
SOURCE: 57.70 error for hp colorlaserjet 9500n
6L/5L Check memory card compatibliity - 1,2,4,8 MB, 5 volt, 70 nanosecond or faster6P/5P/5 Main motor problem, check gear train for binding. Check connections to DC controller - replace main motor
4L/4 Main motor problem, check gear train for binding. Replace main motor
IIIP/IIP+/IIP Error 57-1 Incompatible memory can be either top or bottom slot. Also check motor cable connections. Replace main motor. Can also be DC controller.
5Si/4+/4Si/IIISi (X=2, 3 or 4) Fan motor faulty, check fan number X or duplexor fan and replace as necessary
5 Main motor failure - replace main motor
4+ 57.1 Gears are siezed, motor is bad or DC controller is bad
4Si/IIISi 57.1 Gears siezed, faulty top cover switch, faulty AC interlock switch, J010 loose or faulty, bad main motor PCA
LJ 4000/405 An error occurred with the Fan’s motor. X = Description
4 Printer Fan 7 Duplex Fan
1. Check the Fan’s connector and make sure the Fan is not blocked.
2. Replace the Fan.
LJ 5100 A temporary printing error occurred. x = description 1—printer fan
1. Check the fan connector and make sure that the fan is not blocked.
2. Replace the fan.
LJ8100/8150 A fan motor failure occurred. All fans are enabled to low speed operation
at power on. Fans will go into high speed operation during the print cycle.
X Description
2 Fan 3 - Formatter Fan (intake)
3 Fan 2 - Laser/scanner (exhaust)
5 Fan 1 -Low-voltage power supply (exhaust)
6 Fan 4 - Face-down delivery (exhaust)
9 Fan 5 - Tray 1 fan
A temporary printing error occurred in one of the printer fans. X represents the fan motor number associated with the error. For example, 1 = fan motor 1. Power the printer off/on to clear error. Replace appropriate fan as needed.
Posted on Mar 09, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: I have installed Windows 7 now How to connect HP
When you installed Win7, did you upgrade or did you do a Clean install? If you performed an upgrade, you may have the problem with older conflicting drivers and services. Read this to see what I mean. http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
Posted on Jul 20, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Posted on Nov 03, 2009
My odl hp 3052 scanner drive cd is not compatabel with win 7 kindly suggest
Hi
The Hp LJ 3020 is compactable with windows 7, Click hear and install the windows os driver.
Jun 10, 2011 | HP LJ 3020 All-In-One Printer / Scanner /...
I am trying to scan multiple documents and have them go into 1 file using Windows fax and scan with my HP3020 all in one printer scanner, this used to happen automatically when I was on XP but recently...
This is the latest version of HP's Universal Print Driver (UPD). The UPD, available in 32 and 64 bit packages, is a single driver that supports PCL5, PCL6, and HP PostScript; level 2 and 3 emulation.
Please review the Release Notes for information on issues resolved, performance improvements, and new behavior changes to the UPD.
Details and specifications File name: s.gif upd-5_1_1_8232-pcl5_win-xp-vista.exe [1/1, 14.6M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Client operating systems supported:
  • Microsoft Windows 7 Starter, Home Premium, Professional, Enterprise, and Ultimate; x86 and x64
  • Microsoft Windows Vista Business, Enterprise, Home Basic, Home Premium, and Ultimate; x86 and x64
  • Microsoft Windows XP (SP2 and later) Home Edition, and Professional; x86 and x64
    *Note: Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the current UPD and tools for the discontinued Windows XP operating system until 2011
thumbs back!
Oct 28, 2010 | HP LaserJet 3020 All-In-One Printer
LJ 3050 printer is printing very slow.
TRY HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet 3050 Printer
Is there any hope for a Vista 64 bit HP Laptop with the HP LJ 2840 Printer? I have tried it all, had Invisus Support work on it for two hours today, 10-25-10, and still no printer functionality. I am...
s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Oct 26, 2010 | HP LaserJet 2840 Printer
I have have downloaded the HP Laserjet 3015 Print driver on my Lenovo U330 Laptop with Windows 7 Ultimate. Unfortunatley, I've tried 2-3 times to with no success. Am I having a compatiblity issue with...
File name: s.gif upd-5_1_1_8232-pcl5_winxp-vista-x64.exe [1/1, 15.21M] System requirements: s.gif Client and server operated systems supported for the most current release of the UPD:
Oct 25, 2010 | HP LaserJet 3015 All-In-One Printer
I loaded Win 7. I need my printer to work badly. I have to print checks. I have a Laserjet 1022 Is there a driver or bata driver I can use.
Go to the HP website (www.hp.com) > click download drivers and firmware or support > type in HP laserjet 1022 > click the search arrows > click on you printer model > choose the operating system. If Windows 7 drivers aren't available yet the Windows Vista drivers should work just as well for the time being.
Oct 26, 2009 | HP LaserJet 1022 Printer
HP LJ 1005 installation end with driver conflict
That's wrong, The HPLJ1005 doesn't support windows vista.
Altough, the link cene765 is pointing to is for the HPLJ1005P which has vista drivers though these are two completely different printers. Searching the web for custom drivers now, will post solution if finding any.
Tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Feb 06, 2009 | TimeValue Software TValue 4.0 for PC
Can not get a hp lj 1022 installed
Go to www.hp.com and let the website auto-detect your printer and down load the drivers automatically
Jan 16, 2009 | HP LaserJet 1022 Printer
HP Laserjet 1022
Try to clear dust from cylinders..
I had similar problem and I cleared dust from cylinders with ear sticks and destilled water.
good luck :))
Aug 12, 2008 | HP LaserJet 1022 Printer
Dell 924 All-in-One InkJet Printer Logo
1,603 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
