Question about Epson TM-T88III Thermal Printer
How to make Epson thermal printer print darker?
What switches to I need to change to make this thermal printer print
darkest? Any help appreciated. Thanks
  • Raceful Jun 17, 2008
    Thanks, you have been very helpful. Mine works better now.
    Raceful
    Genius:
  • 1,447 Answers
Change the dip switches settings to
PLS DONT FORGET TO RATE AS FIXYA, THANKS!!
Posted on Apr 25, 2008
How do i change the ink
The Epson TM-T88III is a thermal printer so it does not use ink, it prints on special thermal paper only. Be sure you have the correct paper in the unit. If it is correct and the printer still does not print then you have a problem with the print head and the printer will need to go in for service.
Sep 25, 2012 | Epson TM-T88III Thermal Printer
Tip
How to determine the formula of ribbon you need
Not all thermal transfer ribbon formulas print on all materials, the key is to match the label material with the proper ribbon. There are three main types of ribbon formulations used in most thermal printers.
Wax -
  • the least expensive
  • works best on thermal transfer paper labels (it may print on the other materials to some degree but will easily scratch off)
  • looks the darkest (more opaque) when unrolled and held in front of a light
Wax / Resin
  • this is a very wide ranging category, some formulas are the same price as wax, others can be almost the same price as resin
  • works best on thermal transfer labels paper, preprinted thermal transfer labels, and many polypropylene materials
Resin
  • the most expensive
  • the most durable
  • is UL approved when matched with a compatible material
  • works best on polyester and polyolefin
  • looks the lightest (more translucent) when unrolled and held in front of a light
on Aug 20, 2010 | Office Equipment & Supplies
Rimage everest 2 prints get darker after 10 prints
1. for print cartridge2.for print media
3.for room temperature not adjust with printer needed .
4bad contact with print cartridge and the printer
Aug 29, 2012 | Rimage Everest II Printer
I have a SRP350 thermal printer that prints faint, is there a setting that makes it print dark? Thank you
The printer has some dipswitches under the panel on the bottom of the printer. Dipswitch 2-5 needs to be OFF and dipswitch 2-6 needs to be ON for darkest print. Default is medium. This printer is 180dpi so recommend using double size characters for darkest printing.
Aug 24, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My copies come out way too light but when printing from computer prints fine. do i need to change out something that is specific to copying rather than in the actual printing of things? Thanks for any...
That not a problem, that OK
some of the printer low quality is working like that as you have not specify your printer brand name and model name that all i can answer it
Mar 19, 2011 | Office Equipment & Supplies
Hi, On a Zebra S600 printer... How to change setup for print method (actually it showing up direct thermal) and we would like to change the print method to (Thermal trans). Thanks! Pierre Tardif
The easiest way may be to change your printing preferences at the driver level. We use Seagull Scientific Drivers (They are free to download).
If you use the Seagull Driver go to your Printers Folder, "Right Click" your printer and go to Properties
Then Go to the General Tab then Printing Preferences then Stock Tab then Print Method. Click on the Down Arrow and change to THERMAL TRANSFER.
If your using a label printing package make sure your settings are for Thermal Transfer since they can override default printer settings.
Good Luck
Mikeo@acebarcode.com
Feb 16, 2011 | Zebra Stripe S600 Thermal Label Printer
Changed the ribbon, but the labels are to light.
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
May 07, 2010 | Zebra 105SL Thermal Label Printer
Epson TM-T88III Thermal Printer Logo
2,713 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
