Question about NetGear WNR2000 Wireless Router
Cant login to Netgear WNR2000
I have some problems with my Netgear WNR2000. I connect 2 laptops, an xbox360 and a mobile phone to it.
Everything connects fine, except for the phone. It cannot obtain an IP address. I cannot log into to the router either. When ever I try to login it get forwarded to: http://kb.netgear.com/app/home
On the rare occasions that the phone does actually connect, it connects immediately and with no problems. When the phone connects to the router, I CAN login into the router just fine. When the phone can't connect, I can't login to the router.
Restarting the router or doing a factory reset does not help.
Any ideas?
Thanks
redhaze89
  • 854 Answers
SOURCE: Myh new Netgear WNR2000 won't connect to my cable
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 11, 2009
  • 27 Answers
SOURCE: Problems connecting with a Netgear WNR2000
your easiest solution is probably just to reset everything back to defualt settings. there is a small pin hole button on the back or bottom to do this.
hope this helps!
Posted on Aug 24, 2009
SOURCE: Can't obtain IP - Net Gear WNR2000 router
Try to open the Router page using "ROUTERLOGIN.COM" in IE and go to WAN Setup option in which u can see Disable SPI Firewall (check the box), also reduce the MTU Size to 1400 or 1390
Posted on Sep 16, 2009
PC Commando
  • 142 Answers
SOURCE: xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Posted on Sep 19, 2009
SOURCE: lost install disk
You don't even need the installation disk! Just do these easy steps:
Plug in your PC directly to your router. And make sure it is turned on. Also plug in your MODEM into the routers modem port.
On your computer open up Internet Explorer. Then in the address box type in: routerlogin,net
User: admin Pass: password
if password for the password does not work then just leave the box blank. Then just complete the steps.
If this works or if you need help then PLEASE email me:
pmt47@comcast.net
email me wither it works or not!
Posted on Mar 28, 2010
Cant log in using 192.168.1.1. I like to change to an SSID
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Sep 17, 2011 | NetGear WNR2000 Wireless Router
Problem with NETGEAR Wireless router WNR2000 and DSL hookup. If I run westell 6100 DSL router independentlly on my desktop [windows XP] it works fine. But when I go thru the netgear router, both my Desktop...
1. If you can upgrafe firmware on router that can fix your problem
2. you can go to netgear website for latest firmware on router(you can download from there)
Mar 03, 2010 | NetGear WNR2000 Wireless Router
I have purchased a NETGEAR wireless n router WNR2000 every time my son goes on his laptop and connects to the internet it connects and then it drops out and it keeps doing that what can I do
if it is a 2.4 giga hertz router, then make sure the router or laptop are away from cordless phones or microwave ovens, as most of these operate near the same frequency. Also, double check the wireless settings on both the router and laptop to make sure both are the same. Hope this helps!
Oct 19, 2009 | NetGear WNR2000 Wireless Router
Sep 16, 2009 | NetGear WNR2000 Wireless Router
hope this helps!
Aug 24, 2009 | NetGear WNR2000 Wireless Router
NetGear WNR2000 Wireless Router Logo
837 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
