Question about Acer TravelMate 3260-4484 Notebook
Keyboard problem when i press the button the k, the numeric 2 will come out instead of k. these happened to button u,i,o,p,j,k,l,and m. how can i reset back to the current mode where the alphabet come out?
  • 1,675 Answers
Hi this is simple..press the Fn ( function key ) this will get the letters back to normal..hope this helps
Posted on Aug 01, 2010
What happen to my keyboard? When i typing button '@', sign " will appear. And same situation when i typing button ", sign @ will appear. Look a like " and @ swap. -fairulazwan@gmail.com-
You are using wrong keyboard type.
Numeric button 2 has @ sing in USA Keyboard and in UK Style Keyboard Numeric Button 2 has ".
Dec 26, 2014 | Lenovo Keyboard
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
My acer travelmate 2410 the letters I o p j k l are typing the numbers 1 to 6 Instead
Has anyone spilled any liquid onto the keyboard?
This is a common indicator as to why the keyboard gives wrong character inputs.
If this is the problem, the keyboard will need replacing
If this is not the case try pressing the FN and NUMlock keys together
Jul 25, 2011 | Acer Computers & Internet
Keyboard functions failing 0123456* instead of mjkluioP
There is a "keypad" button somewhere on the keyboard, to cause those alphabetic keys to instead be interpreted like the keys on an adding-machine (or hand-calculator) -- very handy if you need to enter a lot of numeric data, and you are a "touch-typist" when using a hand-calculator.
Press the button to return the keyboard to "normal" mode.
Jul 16, 2011 | IBM ThinkPad T40 2373 Notebook
Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
You have turned on the numeric keys on your laptop. It is turned off/on by the following.
Press the Num Lock key. If nothing happens, try Shift+Num Lock.
If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
Read more: http://www.dummies.com/how-to/content/the-hidden-numeric-keypad-on-your-laptop.navId-323018.html#ixzz0vfEI4Odm
Aug 04, 2010 | Computers & Internet
On my laptop alphabet keys uiojkl and m have numbers on them i dont know what i pressed but whenever i use the keyboard now it will only type the numerals that are on those keys instead of the letters...
please check for a the ( Fn) key which is found next to the left side ctrl marked by a blue colour. cleck to see if this is jammed as only by holding the fn key down will the alphabets change to numerical. If the fault is persisting again open your keyboards settings and check for default settings. Also try to reinstall the drivers or else restore you computer to an earlier good restore point by clicking on control panel, select back up /restore. I hope this clears your fault. Good day.
Jun 30, 2010 | Acer NSK8458AN Keyboard
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
I love my keyboard but when I press apostrophe quotes they don't appear unless I press the button twice and then I get double and have to backspace to get single quotations again.
Hi
I beleave that is how that button is supposed to work, on all the keyboards i've ever used the same thing has happened, instead I press on the " key instead of the ¨. I suppose the " is what your looking for instead of the ¨.
I'd guess your pressing on the wrong button, find the key that does " " " ", you may use SHIFT together with another key to get " to come out.
On my Finnish keyboard its SHIFT + 2 .. = "
Dec 22, 2009 | Microsoft Wireless Optical Desktop 1000...
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
When i press shift+2 i get " instead of this @
Press the other Shift button, OR press the ALT GR button which is the button on right from the long space bar.
So ALT GR + 2 will give you a unlimited suply of @ @ @ @ @ @@@@@@@@@@@@@@@@@@@@@@@@
Jun 18, 2009 | Dell 0Y3740 Keyboard
Acer TravelMate 3260-4484 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
