Ok i downloaded a boot disk now its saying no valid device driver mscd0001
    President:
  • 4,070 Answers
Hi! One problem that can cause this is a faulty cd rom or a corrupted file of boot disk. Try this, save the boot file on a usb then try if it will boot. If it boots up then its a faulty cd rom, if not then its a corrupted file. Hope this helps and have a good one!
Posted on Aug 01, 2010
Pxe-e61 media test failure check cable
The PXE error message suggests that your computer is trying to perform a network boot which is why it is saying there is a cable issue.
Check your BIOS settings and disable the option to boot from the Network, plus check that the computer is configured to boot from a valid internal hard disk drive. It is Ok to have a CD or USB device listed ahead of the hard drive in the Boot order as this is normal to allow booting from CD or DVD media or USB devices.
Check that internal hard disk is operational, that the cables to it are firmly connected at both ends (the drive and the motherboard).
If you still have a problem, then provide more information on what symptoms or error messages your are seeing.
Jan 11, 2012 | eMachines C3070 PC Desktop
DISK DRIVE NOT WORKING
If your Hard Disk Drive (HDD) is not working and assuming that this is also your boot disk for starting the laptop, then you have several possible causes:
1. The HDD has failed / died / become non-operational and will need to be replaced and your operating system reloaded or restored from a backup if you have one.
2. The computer BIOS has lost the configuration for the HDD and doesn't recognise it as a valid boot device. In this case, you would need to go into the BIOS settings and check to see what HDD devices are beig detected, then look at the Boot options within the settings and ensure that the HDD is selected as the main boot device.
Note: It is normal to have other removable devices set ahead of the HDD such as CD / Diskette or USB devices.
3. The HDD boot sector has become corrupted and the computer no longer recognises the disk as a valid boot medium. You would need to repair the HDD if this is possible using an alternative boot media such as the Hiren's Boot CD which you would need to download as an ISO CD image then burn on to a blank CD disc, then boot from. The DOS programs on the Hiren's CD provide a very good HDD repair tool called HDAT2.
An alternative approach would be to remove the HDD from the laptop and connect it as a slave in a different computer and then perform any repair activities from that system.
Jan 06, 2012 | Dell Computers & Internet
Hdd not found
If your Hard Disk Drive (HDD) is not found and assuming that this is also your boot disk for starting the laptop, then you have several possible causes:
3. The HDD boot sector has become corrupted and the computer no longer recognises the disk as a valid boot medium. You would need to repair the HDD is this is possible using an alternative boot media such as the Hiren's Boot CD which you would need to download as an ISO CD image then burn on to a blank CD disc, then boot from. The DOS programs on the Hiren's CD provide a very good HDD repair tool called HDAT2.
Jan 04, 2012 | Computers & Internet
How to boot my laptop into usb drive
You have not specified your operating system. However I will explain how to do it with windows 7. First you have to create a bootable flash drive. Do it as follows
Format USB flash drive to NTFS format(For Win XP only. Vista users can directly format the USB drive to NTFS format) In your Windows, go to Control panel -> system -> hardware -> Device manager.
Under the disk drives section, right click on the USB storage drive and select Properties.
device-properties.pngGo to the Policies tab, select optimize for performance. Click OK.
device-policy.pngOpen your Windows Explorer, you should see the USB storage drive in the inventory. Right click and select Format. Select NTFS from the drop down bar. Click Start.
format-ntfs.pngFor Windows XP,
Download MBRWizard. Extract the zipped files to your desktop.
Open a command prompt (Start -> Program -> Accessories -> Command Prompt).
cd Desktop/MBRWiz2.0/
MBRWiz /list
Record the USB flash drive disk number
mbrwiz-list.pngMake the USB drive active.
mbrwiz /disk=X /active=1
For Windows Vista,
On the Start menu, navigate to the command prompt entry. Right-click and select Run as administrator.
vista-command-prompt.pngType
diskpart
list disk
Record the disk number of your USB flash drive.
vista-diskpart.pngSelect the USB disk.
select disk X (X is the drive number of the USB flash drive)
List the current partition. Record the partition number.
list partition
Select the current partition and make it active.
select partition Y (Y is the partition number of the USB flash drive)
active
list-partition-vista.png Creating bootable USB flash driveDownload Windows 7 iso (32-bit) file to your desktop (The download link is no longer valid).
Download and install WinRAR.
Right-click on the Windows 7 iso file and select Extract files. Extract the files to a folder (you can name the folder any name you want, but for illustration purpose, I name it win-7) in your desktop.
extract-win-7.pngIn your command prompt, cd to the windows 7 folder.
cd Desktop/win-7 (Change the destination to the folder that you have extracted)
cd boot
bootsect /nt60 X: (X is the drive latter of your USB drive )
bootsect-success.pngNow, copy all the files from the Windows 7 folder to the USB flash drive.
Reboot the computer. Remember to change the first boot device to your USB drive in the BIOS.
You should be able to install Windows 7 from your USB flash drive now.
Apr 26, 2011 | Sony Vaio Pcg-Z505N/Bp...
I just bought a sylvania netbook and it says i need to update my web browser.when i download the ones they show it says not a valid windows ce application.what do i need to do besides pull out a...
ok sounds like you have a bit of a problem here. this device should not come with Windows CE installed on it.
Did you get any isntallation disks with the device? if so try re-installing the operating system that came with the device.
Dec 18, 2010 | Sylvania G-Netbook
Ghost disc will not boot, not recognized as valid windows copy
If it's a Norton disk, call Norton, it should be bootable. If it's a disk you burned, it may not be a bootable system disk. Make sure your computer is set to boot from CD/DVD drive in the bios (setup) Press F2(usually, sometimes it's delete) while booting, go into setup, and make sure under boot devices/sequence that your disk drive is first in the boot sequence. Try the disk on another machine to see if it's the disk, or the machine. If it's the disk, Call Norton (if it's theirs) or have someone make another one for you.
Jun 12, 2010 | Symantec Norton Ghost 14.0: Windows
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
In the screen say wait no boot bios
"No boot BIOS" or "No boot ROM" are the default messages when there's no hard disk to boot from, or when the hard disk does not contain a valid operative system, or is not marked as bootable. Also, if the hard disk is not among the units to boot from.
Check the system configuration, then the hard disk.
Nov 09, 2009 | ASUS S-presso Standard S1-P112...
Recovery disk needed
reboot
on reboot, enter BIOS setup, F1 Esc, whatever the prompts say
and change the boot sequence to a valid drive.
This may not work since you did not say what occurred to __kup the boot sequence
Sep 20, 2008 | Insignia D300a PC Desktop
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
