Question about Panasonic TH-46PZ800U Plasma TV
Panasonic th46p tv wont turn back on after its been in standby
Tv wont turn back on after its been in standby for 5 minutes i have to switch it off and on again with the power button then press the standby button on the remote. any help would be great. thanks
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
Kimi
  • 277 Answers
SOURCE: Panasonic TH-50PV30
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Dec 22, 2005
  • 346 Answers
SOURCE: panasonic plasma tv viera 42inch
transistor problem
Posted on Dec 29, 2007
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
  • 1894 Answers
was that capacitor damaged?
Posted on Jan 11, 2008
My Panasonic viera wont turn on from standby. It has a solid red light, no flashing
Hi Cloda,
It is mostly the power supply section which gets damaged due to power surge. In many cases the damage is repairable. Please contact some local TV tech.
Good Luck.
Jan 13, 2016 | Panasonic VIERA Televison & Video
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Why is my panasonic tc-p46x3 is blinking 14 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 10, 2014 | Panasonic Viera Plasma TV TC-P46X3
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Panasonic TH42PZ85B troubleshooting standby light flashing red and TV will not come on line?
Have exactly the same problem. Standby light flashing twice in 1 second then off for 5 seconds but will not switch on. This after switching off on the set following around 1 hour use.
Switched all power to set off for around 30-40 minutes
Jul 02, 2010 | Panasonic Televison & Video
My Polytron TV is on standby mode. I used the remote but wont turned off
When you turn that TV "off" with the remote it go's into standby mode, that is the way they made it unfortunatly
To actualy make it not have any power going to it you will have to unplug it or plug it into a power strip and use the switch on the power strip.
They use the standby mode to allow the TV to turn on quickly without making you wait.
Jul 19, 2009 | Panasonic Televison & Video
The TV switches it self off
Sorry to here about your TV problems but it is almost imposable to help someone with technical problems if they don't list a product, model or P/N number.
Either-way, I would try moving the unit in an area where it has more breathing space if poss-able.
Also, is the unit in a air conditioned area or in a Damp basement or Florida room ?
I would also, go on line and see if Panasonic has any call backs on this unit.
This may be a feature which can be reset without to much trouble.
Next time please list the size & model #.
Jun 16, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
50 inch samsung wont turn on standby continues to blink
Try unplugging it from the wall for 5 minutes and plug back in .. let me know what happens
Jan 03, 2009 | Samsung DLP HL-P5663W 56" TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Panasonic TH-46PZ800U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
