Question about Cell Phones
I need to find an online manual. My question is, given that the ringer is in the phone and base unit, can you turn the ringer off on both?
  • hkdowson Aug 01, 2010
    Oops, apologies - I thought the make and model was in the header when I posted the question! It's a Panasonic KX-TG6424. Hope you can help! Many thanks.
    President:
  • 2,030 Answers
Need to know what Make and Model phone you have first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
How do i unmute the ringer on my vtech dect 6.0 phone
Hi Angie.
The manual for this phone can be viewed here:
http://cdn-media.vtechphones.com/ecp/documents/product_Product/1681/UserManual/6351/ls6425-3_manual_i3.pdf
On Manual Page 20 / pdf page 23, it says that if the ringer is muted for a single call, that it should work again the next time someone calls.
However. page 57 notes that the base ringer volume can be set between 0 and 6, so it's possible your ringer volume is not technically muted, but just turned all the way down.
Manual page 62/pdf 67 has a half-page list of other reasons that the ringer might not ring. (It can also be turned off, and there are different adjustments for both the phone and the base unit.
Hoing this lets you figure it out!
D
Dec 03, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I reenable the ringer on my ATT 993 phone. The phone does not ring
Make sure to look on the phone itself, and see if there might be a button on the unit, or base station, that turns the ringer on/off.
Feb 21, 2015 | AT&T High Quality ATT 993 2 LINE...
Handset does not ring but the answering machine unit does
Go into menu settings from head set and make sure ringer type is slected for a tone and then check and set volume at desired level
Apr 15, 2013 | Uniden 2.4 GHz Cordless Phone System
How do you turn off the base ringer?
You don't have to unplug anything. Just set the ringer volume (feature code 11) to 0.
Full details are on page 27 of the manual.
Mar 16, 2012 | Panasonic KX-TG6022B Phone
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
How do I get the ringer to work? It was working fine until it was unplugged. It was given to me used so I don't know the exact model but it is a 5.8Ghz digital with the answering system. Thanks! Jim
Take a look at both the handset and the base. On one of them you should find a ringer on/off switch. It probably got bumped to the off position. Your model number should be on a label on the bottom or rear of the base unit. Owner's manuals for most phones are available from the manufacturer's website.
Mar 01, 2010 | Vtech Digital Cordless Telephone VT-2568
VTECH CS5121 Need to turn off ringers on base and handheld
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314062
Jul 29, 2009 | Vtech CS5121 Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Ringer
Hold the Low volume key on the base unit for sometime. A beep will sound that means the ringer of the base unit is off.
Feb 18, 2008 | Panasonic KX-TG5632 Phone
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
