Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Can't learn remote buttons in NetCommand
We've owned a WD-52525 for a little over three years now. I originally setup NetCommand when we got it and while the learning curve was steep, I managed to get everything working. Last year, when we got the bulb changed, my NetCommand setup was lost, so I had to re-do everything. I had enough problems that I only did as much as I could find time for, and lived with the few issues I still had.
A couple days ago, we finally decided to try out digital cable from our cable company. After trying two CableCards, neither worked. (One refused to connect back to the office and the other the TV claimed was invalid.) I punted and opted for the cable box.
Since my cables had gotten to be quite a mess, and since I had enough lingering problems from my haphazard re-programming last year, I decided to re-wire everything and re-program NetCommand from scratch.
Sadly, though, although I can add devices in NetCommand, I cannot get it to learn any of the commands from the other remotes! Not a single command on any of the remotes. I remember doing this before, and can't figure out why it won't work. Repeatedly pressing the button while the command label flashes yellow does nothing, and it eventually times out and stops flashing. Repeating this, trying every angle and distance from the TV I can think, has no effect. I can tell the remote's working, as I have to cover up the desired device to stop it from acting on the remote's commands, even from steep angles. The batteries on the other remotes are fresh.
Is there a known issue that causes this? Am I missing something obvious?
I had the same problem. You need to clean the mirror and lens. The learn remote apparently uses the same mirror. Mine would not learn any new commands. After cleaning the mirrors and lens inside the TV, the picture improvement was incredible and the learn function works fine. The dust builds up gradually on the mirrors so you don't notice the difference in the picture as it degrades.
Posted on Aug 23, 2009
  • 126 Answers
Kinda sounds like you are putting the first steps in right like the remote is excepting the command but the last step try to hit enter or something sound like it is excepting code but the last step deleteing okay shad
Posted on Jun 21, 2008
How do I unlock a WD-52525 Mitsubishi I have a Rca universal remote I dont know the password
You must use the factory remote. Mutlibrand will not work for this option. No matter the universal remote, you need the original. No other way to do this.
1. Press MENU on original remote only
2. Then press 2,4,7, and 0
3. Select "initialize" and then 'ENTer"
This will full restore to factory original settings. but you need the original Mitsubishi remote.
Feb 25, 2015 | Mitsubishi WD Televison & Video
I have a AVEX URC-R6 Remote controller that was working fine for almost 3 years with a DISH 722 Reciever/DVR. One morning the receiver IR would receive no signals from either the AVEX remote, or the...
trwck
I have provided instructions on how to save setting on the receiver and remote plus instructions for learning mode. I hope this helps.
Ray Calo
DISH Network
Back Up Remote/Receiver Data
  • Receiver: 222k and 722k
    1. Verify that the customer has an unobstructed LOS and is within 10 feet of the receiver. The customer will need to direct the remote toward the receiver for the duration of the System Wizard setup.
    2. Press and hold the number 0 until the pop-up 380 appears on the screen.
    3. Verify that the System Wizard says the remote is configured correctly.
    4. Select Advanced on the screen.
    5. Select "Backup My Settings Now".
    6. Verify that the purple gem is displayed beside the correct selection.
    7. Select Next.
    8. Select the type of backup to be performed:
      • Full system backup
      • Back up receiver settings
      • Back up remote settings
    9. Verify that the purple gem is displayed beside the correct selection.
    10. Select Continue twice to initiate data transfer. Maintain unobstructed LOS while the green progress bar fills.
    11. Select Continue to resume programming.
  • Restore Receiver Data
    4. Select Restore on the screen.
    5. Maintain unobstructed LOS while the green progress bar fills.
    6. Select Continue to resume programming.
  • Teach Learning Commands
  • Receivers: 222k and 722k
    1. Ensure the DISH Network remote control is programmed to the desired remote address to operate the DISH Receiver.
    2. Place both the DISH Network remote and the original equipment's remote control on a flat, stable surface.
    3. On the DISH Network remote, press and hold the mode button for your equipment for about three seconds until all of the mode buttons light up, and then release it. Your selected mode button will blink.
    4. Select the type of learning you wish to perform:
      • Hybrid Mode
        1. Press and release RECALL, then hold the RECORD button for about three seconds until the mode button is lit again. The button remains lit while learning.
        2. Point the front of the original equipment's remote to face the small square (IR window) on the front left-hand side of DISH's remote. Remotes must be within 4 inches of each other.
        3. On the DISH Network remote, press the button you want to teach.
        4. On the original equipment's remote control, press and hold the button you want learned. If the DISH Network remote learns the command, the mode light blinks off and then back on. If the mode light blinks three times or remains lit, the DISH Network remote did not learn the command. You may need to press the button on the original remote several times for the DISH Network remote to learn the command.
        5. After a button has learned a command successfully, repeat steps 3 and 4 until all commands you want have been learned.
        6. To end the learning sequence:
          • Press one of the mode buttons on the DISH Network remote. This saves all of the commands for that mode and exits learning to return to normal remote control operation.
      • Normal Mode
        1. Press and hold the RECORD button for about three seconds until the mode button is lit. The button remains lit while learning.
  • Mar 25, 2011 | DISH Network ViP722 DTV Receiver /...
    Need help with Harmony One remote and Mits WD-65736
    To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
    Open the Mitsubishi Television's setup menu.
    Select Delete at the setup menu.
    Select Entire Configuration and then select Next.
    Follow the onscreen instructions to delete the entire configuration.
    To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
    #messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
    Feb 01, 2010 | Mitsubishi WD-65736 Television
    The remote operates all the units except for the TV's vol, channe
    There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
    You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
    There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
    If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
    michtech
    Feb 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    I have a mitsubishi 52525 I am at the menu screen and the antenna icon is not accessible
    you either need to add it with the netcommand function, or reset the set with "menu 2470 enter"
    Dec 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
    Blinking Green Light on Mitsubishi DLP 52525
    The 52525 is definitely going to either:
    1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
    2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
    wait time: 4-8 weeks
    cost to rebuild: $400-$500
    cost for labor: $200-$400
    Oct 13, 2008 | Mitsubishi WD-52627 52" Television
    NetCommand remote control
    make it sure you're on the right atenne, if not you can use both...
    Oct 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
    Blue screen and shut off by self
    You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
    Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
    Mitsubishi WD 52525 & PS 3
    First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
    Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
    Mitsubishi WD-52525 52" Rear Projection HDTV Logo
    90 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
