Question about Dell 3100cn Laser Printer
My Dell 3110cn laser printer recently started to print pages that appear dirty. The entire page has a grey tint to it. I removed the toner cartridge to find alot of toner dust all over the cartridge. I think it is just in need of cleaning. How to I clean it?
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
Feb 17, 2010 | Dell 3110cn Laser Printer
Dell 3110cn Printer prints shades of pink
Have you pulled out the imaging drum and transfer roller to see if they are caked in Magenta toner? if so they will need to be cleaned off. Would also suggest blowing out the area around the drum to rid of loose toner in that area.
Feb 15, 2010 | Dell 3110cn Laser Printer
Dell 3110cn Color Laser Printer Certain colors will not adhere to the page when printed on heavy paper. Combination of green/black wipes off the paper when rubbed.
Either the paper is just too thick for the printer to fuse the toner correctly, or you've NOT selected the right paper type (in the printer driver options.
If you're just printing that same as you would on ordinary A4 paper, the fuser can't get enough heat through the thick paper to fuse the toner.
May be a wrong toner problem if you've done this successfully before, but only had this problem since changing toner cartridge(s)
Oct 19, 2009 | Dell 3110cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Printer Repeatedly Prints exactly 6 pages then reports a jam.
It is problem Fuser unite thermostater is not properly install or or toner dust
May 29, 2009 | Dell 3110cn Laser Printer
Recently changed the black toner cartridge in the Dell 3110cn printer. This past week when I print the entire page is being printed with a shade of gray. I think the toner cartridge has leaked toner and...
This could be a drum problem, the drum is part of the toner cartridge in this printer.
If the toner has leaked it will be all over the inside of the printer - you'll see it. I don't think that's the problem.
If the toner cartridge is an original Dell item, then it's likely to be replacable under warranty.
If the cartridge is a remanufactured item, it may be that the wrong toner has been used. Toner is NOT all the same, and this cartridge is one whe the wrong toner really will not work properly for long.
The chances are the changing the toner cartidge will cure the problem, provided you use an original Dell item, or a remanufactured item from a reputable manufacturer.
Apr 19, 2009 | Dell 3110cn Laser Printer
Dell 3110cn color laser prints with black "haze" on all pages
You probably used a "GENERIC" toner cartridge on one of your toners.
This caused the developers to get contaminated, now they need to be replaced (probably Black & Blue)
Jan 12, 2009 | Dell 5100cn Laser Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Dell 3100cn Laser Printer Logo
498 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
