Question about Samsung R610-64G Laptop
Computer starts but touch pad not working so no pointer so cant get into contol panel or programs
    Scholar:
  • 110 Answers
You will need to boot into safe mode - by pressing the F8 key once every second during bootup until you get an option menu and select "safe mode with networking support". Once it starts your touchpad should work - then you will be able to go into your Control Panel to re-install the drivers for the touchpad - Then reboot.
The other way is to use your "Start" key (bottom left on your keyboard between the ctl and alt keys) then TAB key to your control panel - and the space key in place of a mouse click.
Good Luck
Posted on Aug 24, 2010
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
The curser pad on computer, dosn't operate pointer, yet the pointer only moves with wire less mouse any suggestions??
Make sure the touchpad is ENABLED in your Control Panel Settings.
In Windows XP...
Click START.
SETTINGS
CONTROL PANEL
MOUSE
Then DEVICE SETTINGS tab.
Click ENABLE.
Then APPLY.
Then OK.
Good luck.
Mar 05, 2011 | Computers & Internet
Toshiba Satellite Pro L450 Touch Pad Scroll Doesn't work
"Hi sara_sara_ab, let's see if we can fix this problem"
I. "To "Enable" the Pointer Device using the Touch-Pad, go to, Control Panel, click on the "Start Button."paul7of9_16.png in the [Right] short-cutmenu, select to open the Control Panel. In the next window, choose the ("Mouse") applet,paul7of9_17.png in the "Hardware and Sound" category; go to, "Device Settings" in the (Devices) block.
II. "Highlight"; the item you want to (enable) this beingpaul7of9_19.png the Pointer Device." Click the (Enable) button,paul7of9_22.png just below. Be sure to (Click) on the "Apply" button, paul7of9_20.png and click OK. "III.You may need to "Update Drivers?" Click on "Hardware, click "Properties," click, on Driver." If the, Update Driver (block) is not "Grayed-out;" click "Update Driver," and click (OK), this will ensure that the application take effect. paul7of9_23.png
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
Hope this Fix it. "Please find the time to give a "Helpful Rating," and thanks for using Fix'Ya, paul70f9."
Dec 09, 2010 | Toshiba Computers & Internet
Touch pad unlock
below the touch pad is an on/off button/switch.... try that...
then, if that doesn't work, restart the computer, try again....
or... if all else fails...
Plug in a usb mouse, navigate to
Start >
>Control Panel
>Hardware & Sound Devices
>Mouse/pointer devices... check to see that the touchpad is enabled.
Jul 06, 2010 | Compaq Presario CQ60-220US PC Laptop
SATELLITE PRO L300-EZ1004X T5870 2.0G 1GB 160GB DVDRW 15.4IN PC Notebook: touch pad not working...
“Hi, “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware2_bing.gif and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers2_bing.gif?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver2_bing.gif”, click (OK), this will ensure that the application take effect.
"Rating the solution is your way of letting me know if it (helped or not), thanks"
May 06, 2010 | Toshiba Satellite Pro L300-EZ1004X...
The scroll down touch pad wont work
Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. "I hope this will fix it, rating it is appreciated, thanks"
Mar 13, 2010 | Acer Computers & Internet
Im using a DELL LATITUDE D620 the touchpad isn't working and one day I found out I have to +ALT to move my cursor on the touchpad,anyway to fix this ?
Looks like you may have inadvertently pressed the Function (FN) key associated with the touchpad. try re-enabling it by pressing Function(FN) and the corresponding F key. For my computer it's F5...but on others it has been F7...just look for the symbol that looks like a touchpad. This should cover it. (: Good Luck!
Jan 26, 2010 | Dell F3534 Touchpad
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Samsung R610-64G Laptop Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
