Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
I need too seperate top from bottom so i can move my tv, whats the best way
  • Hitachi Master
  • 12,061 Answers
The BEST way is to use professional movers, as usually when self moved they end up in someones workshop, or the scrap heap. Moving these units without special equipment and packaging is thwart with peril. You must be very very careful,it is best to ship it, as one unit. I see so many units that have been moved by the owner, and not done correctly, you need padding and NO jarring it knocks, it must be done Oh so carefully. In ONE unit. They ate just to delicate for words. get it moved by professionals you will not be sorry. Otherwise take extreme care also when transporting it MUST be vibration free. and packaged like glass.
Posted on Aug 01, 2010
Can you easily seperate the top and bottom of the ws 65807 for moving?
Yes. I have the ws-65809, which is virtually the same model. There are 4 rubber plugs that come out on the sides of the TV. under these are four screws. WARNING! You must disconnect the wires connected to the screen before removing the screen or removing the top half of the TV. If you don't the wires will rip out. I believe they disconnect with 2 clips.
May 14, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Can I disassemble my Sony KP-57w-s500 to move from one room to another? It is too big in one piece. Can I separate the top from the bottom?
The only TV's I worked on that the upper and lower halves would seperate was a Hitachi 65 inch projection. So to sum up the answer, no you can not seperate this set.
Nov 03, 2009 | Televison & Video
Can am Hitachi 50GX49B rear Projection TV be diassembled to move it to an area where narrow stairs prevent the complete unit to be mover through this area? I have noticed that inside there are 3 screws on...
Removing the screen is your best bet -
1 Remove speaker grill
2 remove 4 screws holding the screen frame
3 then lossen the bottom corners where the screen meets the frame by pulling outward (some force is required) and work your way upwards towards the top (two people may be required for support)
4 tilt the loosened frame(20-30degrees) from the bottom up and the top shoul lift and seperate from the frame.
After the screen is of you'll be able to tell what to remove next.
Good Luck!
Sep 21, 2009 | Hitachi 50GX49B 50" Rear Projection...
Agitator top does not move during cycle. Bottom
Hi, You will need to change the dog kit inside the agitator. Remove the cap on top of the agitator and you will find a 7/16" bolt. Remove the bolt and seperate the agitator. The dog kit is located betwee the 2 pieces.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 16, 2009 | Washing Machines
Need to know if TV can be separted into 2 pieces
Yes it can and does come apart in 2 fairly equal sized pieces. There are some screws on the sides when removed the top half with the mirror will lift off. It may require some extra force the first time it is done but comes apart with ease after that
Feb 25, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony KP-53XBR35 TV Concave top & Bottom in wide screen, along with color distortion around sides
thats usually a convergence IC failure, Are you able to move the red and blue colors in the convergence adjustment menu?
Jul 14, 2008 | Televison & Video
Philips 46" projection TV. "HELP"
You have problems in your vertical area and also sounds like convergence issue. This will need much work on board.
Nov 26, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Seperated colors
this is a common problem you have bad solder connections on the convergenc ics solder them back if this does not fix the problem then replace them k
Nov 03, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
