Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
My Nikon D-40 has a Nikkor 18-55mm lens is jammed and inside there is a loose piece of black plastic that extends through the bottom of the lens opening. I can move it around with my finger but it is too big to come out. This part is a ring shape and It looks like a smaller piece may have broken off one edge, but there doesn't seem to be any other part loose in there. Can you tell me what can be done to fix it?
If you are experienced or brave enough, dismantle the lens from the rear until you can recover the loose piece. You will probably find that the rear cluster of lenses has fallen off the other end of the helical cam tracks on which it travels. This happens because the two steel strips have got bent. They should run exactly parallel to the axis of the tube. Remove the two strips (4 screws) and straighten them carefully. Reassembling this lot is difficult. Engage the lens cluster on its tracks--it will fit 3 ways and only one is correct. The loose piece is a light baffle which engages with the back of the lens cluster and again will fit two wrong ways and one correct. It has a projecting lug which travels down a groove in the tube. When I had reassembled mine it still felt stiff and about to seize again and I am sure that excessive friction causes so much force that the steel strips bend and lead to it all falling to pieces. I greased the moving parts with silicone grease (from a plumbers merchant!) --most other lubricants either harden up or damage the plastic. I managed to break the wires to the auto-manual switch but they were easily resoldered. The lens now zooms smoothly and takes good pictures. But take care--it is easy to create more faults as you go.
Posted on Nov 06, 2010
Lens is stuck, rattles inside lens
these lenses are made with mostly plastic parts to reduce cost. if the lens was bumped on the front it is common to break the cams that move the lens in and out, unfortunately it is more cost to repair versus replace. there should be nothing "loose" inside the lens
Jan 16, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
My nikon camera was dropped by a friend.the lens is jammed and wont turn.When i looked inside the lens there was a black plastic ring,and it had come loose,there doesnt seem to be anything else broken,how...
Do you have a lens collimator and other equipment necessary to make sure the lens elements are aligned properly when you put it back together? If not, DO NOT try to take the lens apart yourself, but have it fixed by a trained professional.
Aug 09, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I have a Nikon D50 which I frequently interchanges lenses. My AF-S Nikkor 18-55mm lens has 3 plastic retention flanges attaching to the camera body, and two of these have broken off. Can this be repaired...
without seeing pictures, I'd say you could TRY some plastic epoxy or some type of plastic-specific adhesive. i'm assuming you have the pieces that were broken off. otherwise, i'd say get a new lens...they are relatively reasonable used.
Jan 04, 2010 | Nikon D50 Digital Camera with Nikkor AF-S...
My Nikkor 18-55mm lens is jammed and inside there
Hi. I have this same problem. Have you managed to fix it yet? I've been told that it would cost £100 to fix it, plus a charge of £20 to send it away.
Nov 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I have the 18-55mm lens that came with my D40 kit and found that it has a loose plastic piece that prevents the lens from it's zoom function. It can be seen through the back of the lens and has a tab of...
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Aug 10, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikkor AF 80-200mm f/2.8D ED Lens, with broken auto/manual ring
Depending on where you live, you can take it to an authorized Nikon repair place or just send it back to Nikon.
In the US, they are in Melville, NY and ElSagundo, Ca.
Jul 12, 2009 | Cameras
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
Loose part inside nikkor lens
This part serves no useful purpose if you can fish it out do so!!
Mar 29, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
18-55mm lens won't zoom
DON'T TRY TO FIX THIS YOURSELF! You will only add to the damage. If your lens is in warranty, contact Nikon for instructions to get it repaired. If it is out of warranty, I would either pay Nikon for the repair or take it to a camera repair man.
Dec 27, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
597 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
