Question about Dishwashers
Our GE dishwasher does not seem to be rinseing the dishes very well, can you help? thank you
    Scholar:
  • 150 Answers
Many things can cause washabilty issues: check drain line for high loop it should not go down right out of the garbage disposal it should go up first, too much soap and too clean of dishes at the beginning leaves soap residue,if you clean or rinse the dishes well before you even load them back way off on the soap.
Posted on Apr 25, 2008
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
The dishwasher is not cleaning. It has left a residue all over the dishes especially colored plastic ware glasses. like it doesn't rinse but i have ran the extra rinse cycle and residue is still there. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
Dishes not completely clean or rinsed, and mold
get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Cloudy Dishes
Salt? i know you said you have soft water but probably not enough, the salt replenishes the resin beads so you get a rinse with pure water on the final rinse.
Jan 16, 2009 | GE 24 in. GSD2120C Built-in Dishwasher
Dishwashers Logo
182 people viewed this question
Top Dishwashers Experts
