Question about Kenwood Audio Players & Recorders
Kenwood RX-29 is turning itself off less than a minute after it is turned on.... coming up with "protect" on the display
5 Suggested Answers
  • 3 Answers
SOURCE: kenwood rx29 reciever protection fault
Check the speaker ohms. If you still have the factory ones they are rated at 2ohms. All new stereos need a 4 ohm speaker. I had the same problem with a different kenwood and all I did was change to a set of kenwood speakers and that fixed the problem
Posted on Feb 27, 2010
  • 1454 Answers
SOURCE: The stereo plays for a few minutes and then turns itself off
hello it sound like the output transistor has blown or a capacitor has swelled up
shaun
Posted on Sep 16, 2009
larry james
  • 286 Answers
SOURCE: Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Posted on Apr 24, 2010
Testimonial: "Good feedback!"
dunnbiker
  • 8546 Answers
SOURCE: When i turn on the
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 20, 2011
dunnbiker
  • 8546 Answers
SOURCE: hi when i turn it
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 10, 2011
How do I reset Yamaha rx-a4730 it won't turn on just blinks Manual says it is in circuitry protection mode
Yamaha RX-V650 won't power on - Service manual, repair and unlock ...
forum.eserviceinfo.com/viewtopic.php?t=59945
10 posts - ‎6 authors Posted: Sat Aug 29, 2009 1:26 pm Post subject: Yamaha RX-V650 won't power on ... When i came back from a holliday, my receiver won't power up anymore. .... isn't powered (no voltage on the base) when the receiver doesn't comes on.
Sep 12, 2015 | Yamaha Audio Players & Recorders
No TX/ rx Radio Shack TRC-495
it probably jumped freq. somehow. There is now manual or anything but a picture of this radio and a few tune up rv's but thats it.I have the exact same radio and it works fine If you can put it on an oscilloscope it should tell you right away what the problem is. Then try a frequency counter.
Mar 06, 2014 | Cobra 29 LTD CB Radio
Kenwood rx 29 protect
Is this resolved? If not post more info
May 29, 2013 | Radio Communications
My Kenwood KDC-U453 cd receiver displays "PROTECT" on connection and nothing works - any solutions appreciated!!!!
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Apr 11, 2013 | Kenwood Kdc-u453 Car Audio Radio Iphone...
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
Kenwood kr-v888d after "ON", through 3sec.
May 18, 2011 | Kenwood KR-V5580
I have a kenwood Rx-28 Sterio cassette Radio when you switch on the Power Switch error "Protected" comes on
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the mosfets fitted for both the channels,or a short in any of the primary circuits. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes.
Elimination of the circuits will determine the fault. If so replace the outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit.Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
May 02, 2011 | Audio Players & Recorders
Protect message displayed when I turned my truck on
The radio is protecting itself from a shorted wire. It could be the speaker wire itself or a bad speaker. If you disconnect the speakers one at a time, you'll find the culprit. Use an Ohm meter to test the wire. It should read 4 Ohms (give or take 2 Ohms. Anything else will cause the radio to protect itself. If the rating is low, it is probably the speaker but check the wiring too.
Apr 23, 2011 | Kenwood KDC-MP342U Car CD Player
My Yamaha RX V461 receiver will not turn on. When pressing the ON/STBY button, I hear the familiar "click" when pressing the button and a second one about 1-2 seconds later that comes from the...
Your receiver probably went into protect mode because you were overloading the output stage with concert blast. In some units, protection consists of fuses that blow; in others protection is provided by thermal shutdown devices.
Mar 04, 2017 | Yamaha RX-V461 AV Receiver
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
446 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
