Question about Wytron Technology Wytron-688 DVD Duplicator Controller (1 to 10) Motherboard
DVD-688 check loader mode - Wytron Technology Wytron-688 DVD Duplicator Controller (1 to 10) Motherboard
Check loader..
Check Loader comes from the BIOS. Go into your computer BIOS (tap del del del) and make sure your motherboard BIOS can see the Controller. If not, contact you Mobby manufacture for an upgraded BIOS if your motherboard if it isn't too old, and your controller isn't too ancient either. Next - some controllers and PCI add on cards require to be registered within the BIOS. If it needs to be, you need the floppy or CD from the Controller maker and install it before the Mobby BIOS can see it. Remove the controller, install the BIOS update within your OS then shut down, install the Controller, and reboot.
Or don't reboot, go into the PC BIOS and look if the controller is listed.
Many times, it won't show in the BIOS itself but there will be a Logo and Identification at boot up. So keep your eye on the screen until you pass boot into the OS.
May 10, 2014 | Wytron Technology Wytron-688 DVD...
Tip
Harmony 688 Manual Download
Download Logitech Harmony 688 Remote Control Manual
Have you misplaced your Logitech Harmony 688 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 688 Remote Control Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 30, 2010 | Logitech Harmony 688 LCD Remote Control
I have 688 hunter killer running on Windows 7. It only opens in window mode and the sound effects do not play. Music plays fine. I have already set to run in windows xp compatibility mode and run as...
For the sound effects to work you'll need to download SC (Starcraft) Sound Edit Utility.
Open up the utility and then open up file Sfx.agg found on a standard installation here C:\Program Files\Sonalysts Combat Simulations\688I Hunter_Killer\Sfx
Select all the sound files and extract them and you are done. If curious for me the sound files ended up in the compatibility files.
May 02, 2011 | EA - Electronic Arts 688: Hunter/Killer...
I've got wytron dvd 399 and it stays on detecting drives
if the stayed in detecting drive and when on to hang then there a problem with the dvd399 have the dvd check
Nov 20, 2009 | Wytron Technology Wytron-688 DVD...
Wytron 688 won't make copies from dvd
try some other burning application like nero burning rom, alchohol
Oct 21, 2008 | Wytron Technology Wytron-688 DVD...
How to reassemble the Wytron 688
have you got one set as master and the outher set as slave ?
Jan 12, 2008 | Wytron Technology Wytron-688 DVD...
Wytron Technology Wytron-688 DVD Duplicator Controller (1 to 10) Motherboard Logo
551 people viewed this question
Top Wytron Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wytron Technology Computer and Internet Expert? Answer questions, earn points and help others
