Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Not freezing or getting cold - Kenmore 50522 / 50524 Side by Side Refrigerator
    President:
  • 2,468 Answers
Check the ptc overload on the compressor in the lower rear it unplugs off the compressor and is the start and run input power for the compressor,they get bad,when its removed shake the component and if it rattles and sounds like things are loose inside it this is also a telltale sign its bad
Posted on Aug 01, 2010
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
My Knemore Side By Side Model Number 253.52349302 refrigerator gets too cold, it freezes everything. Have to turn knob to almost off to get refrig to quit freezing.
Hi,There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 13, 2011 | Kenmore Side by Side Refrigerator
What kind of antifreeze should i use?
The question isn't really what type of anti-freeze you should use, but rather what percentage of anti-freeze, coolant you should have for the coming cold weather. If you don't live where it get very cold then about 50/50 should be sufficient. If it gets REALLY cold the you can go as high as 70% anti-freeze to 30% water. They make a device you can get at any auto parts store that will test your anti-freezes ability to withstand cold and possible damage to your cooling system. They might even check it for you,
Good luck.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | 1994 Buick LeSabre
Fridge wont get cold or freeze mbut turns on
Sounds like it has a compressor issue or has had a gas leak so will need regassing. Call a service engineer.
Aug 28, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
606 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
