Question about HP Pavilion dv6000z Notebook
Thanks for the answer
But i already buy a 1..2048 .. 667mhz .. so would it had been better if i got 2.. 1024..ram or is that almost the same ??? just so i know befor i put them in my laptop of it have a dif then i will retrune it and change to 2...1024ram 667mhz but only if its a big dif it will make and aging thanks for the help
    Genius:
  • 1,027 Answers
There is negligible difference. That you bought 1- 2gig ram stick is probably better as it would allow for future upgrade to the max supported. Having 1 stick at 2048mb is the way I would have gone.
Posted on Apr 25, 2008
My monitor samsung 2330 keeps saying check digital signal cable and I've put the cords all in the same way I had them before and now this screen keeps popping up
If you already check your connections and still no answer from what you're doing, do these steps:
  1. check for any beep codes
  2. remove and reinsert your RAM to another memory slot, if it works you have a problem with your RAM, you'll need to buy a new RAM that is compatible with your motherboard
  3. if you here a 1 short beep, that means it already start the booting sequence of your computer but you don't see any boot screen and still the out of range error. You have a defective graphic card.
  4. Is your monitor is a LCD type? if your answer is yes that means your monitor is not compatible with your old graphic card, buy a new graphic card that is compatible with your motherboard and to your LCD monitor. Because old graphic cards or onboard vga cannot hold much more pixels than newer ones that's why you have an out of range error
Aug 01, 2011 | Samsung Computers & Internet
How to boost your pc memory
It all depends on what you mean by boost. I would recommend just buying better/more ram with a better CAS latency and/or speed then the current RAM you have to the fastest compatible RAM for your system. If you need further assistance please let me know and please confirm the model number of your laptop.
Thank you,
Lee
Mar 01, 2011 | Samsung V20 XVC 2400 Notebook
Speed slow
Try defragmenting your hard drive, buying more ram, freeing up disc space, buying a faster processor, removing programs from startup or uninstalling unused programs. If you clarified your problem i could help more, has it always been slow or is it just now that it is slow. I could say in the auto problems area "car slow" and someone would tell me to buy a Ferrari, try making a better question and ill give a better answer.
Nik
Jan 25, 2011 | Computers & Internet
How can i allocate more memory to video card of acer aspire 5100
You can only do that with onboard video cards. If you have an onboard you can choose how much ram to assign to it in your bios settings. However it is limited and if you already have 128 assigned to it, that's probably about all it's gonna give ya. But hey it never hurts to check Assigning your physical memory to your graphics card will result a shortage of your total system memory and your whole system will slow down a bit.
Video cards meant for better processing the graphical content of your system and free up your system's physical memory.[via]
So, if you buy a new and better video card with more memory you will have a fast system with better performance.
Apr 27, 2010 | Acer Aspire 5100 Notebook
Need diagram for 2004 dodge ram 1500 serpintine belt need to put on and is not on truck thank you
If you buy your belt from Autozone the belt routing is on the package,If you already bought the belt you could always buy one from AutoZone and then return it after you use the routing.
Jan 18, 2010 | 2004 Dodge Ram 1500
Hello how much memory can take my compaqN400cnotebook,i can"t find the richt answers
This computer can support a maximum of 512MB RAM,
Since there are 2 slots in this system you can buy 2 - 256 MB SDRAM. . Its better to check your system with the new RAM before purchasing it.
Jul 19, 2009 | Electronics - Others
Ecc
ecc RAM are better RAM install it
Nov 27, 2008 | HP Compaq Evo n610c Notebook
Ram
This are the supported MHZ of your RAM 400 MHz • 333 MHz • 266 MHz, but I suggest you go buy the
400MHZ since that is much higher and it will perform much better with your motherboard and can provide
you a faster speed....
Don't forget to rate the solution FIXYA thank you...............
Nov 07, 2008 | Mercury P4VM800M7 Motherboard
Would like to replace MthBrd (M.B.) in E510 (Dell)
I believe you would be better off if you buy a new case as well as motherboard Dell cases can be restrictive on amount of drives etc you can fit in them
If you do you will need to find a board that will suit your type of ram and video card
RAM is it 168 pin 186 pin 200 pin DDR DDR2 DDR3 etc
video card is it AGP or PCI-E 4X 8X 16X
Aug 07, 2008 | Dell Computers & Internet
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
May 21, 2008 | Intel D845GVSR Motherboard
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
