Question about Philips Audio Players & Recorders
My computer does not recognize my player. this happened when I tried to add new songs. I have room on it because I hooked it up to my computer at work and it recognizes it. any suggestions?
  • maxwell187 Aug 01, 2010
    My computer does not recognize my mp3 player. I ned very basic instructions. ex start by going to the control panel etc...
  • Philips Master
  • 19,396 Answers
Hi.
If a different computer recognizes the player, then the problem is not the player, but either the cable used (if using cable) or the computer itself.
Do the following:
If using USB cable, Hub or extension, replace the cable or bypass it. Connect the player directly to USB if possible.
Disconnect all USB devices from computer. Disconnect the computer from power, at the same time remove battery if the computer is a laptop.Wait ten minutes to allow power draining completely.
Connect back power, keyboard mouse and monitor (if this is a PC), restart and connect the player.
If that does not work, try doing a system restore to a recent date before the problem started. You find system restore on Start>Programs>Accessories>System Tools>System Restore.
All settings will be back to the chosen date.
If using a determined software to sync the player (eg.ITunes), try reinstalling the software.
If still no luck, then there is a system related software problem or an hardware problem with the USB on computer. Common procedure is reinstalling system, and if that does not work, testing for a possible hardware fault.
Try the steps above, usually system restore or disconnecting will fix the problem.
See also: My computer does not recognize the MP3 player
Posted on Aug 01, 2010
  • 4,281 Answers
First make sure usb cable connected to player is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer .
Let me know if you need further assistance.
Thanks for using FixYa
  • 4 more comments
    I am very bad at understanding computer languag. what is the windowns key and rkey sorry
    now I am really an idiot there is no key tha says local
    lets start over where do I start? do I open up windows do I start with my computer
  • Start you computer.
    Then if you use windows xp or vista or win7 then go to start->run or type in search "run" without "" then you can see run in lists then click on run .Then you can see run .Then follow my first email solution and check.Let me know if you need further assistance.Thanks for using FixYa
    this did not work it says the specific service does not exist as an installed service.
  • maxwell187 Aug 02, 2010
    my usb cord is fine and now i have tried to reinstall my mp3 player with no luck. any other suggestions?
Hi. I have a problem. I have iTunes on my computer, when I plug my dad's iPod touch 8gb, my iTunes doesn't recognize it. It's charging the battery but it won't recognize the iPod, so I can't delete...
You can delete songs,video,etc the easy way by doing the following:
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
To read what you do about the computer not recognizing the ipod go to this webpage:
http://support.apple.com/kb/TS1495
Please rate me
Dec 06, 2010 | Audio Players & Recorders
How to get songs onto a Hello Kitty MP4?
Turn on computer, click on Windows Media Player, hook up your player to the computer and it should recognize your player, then you can add your songs you have downloaded in Windows Media Player.
This is a free answer, Please rate med
Oct 16, 2010 | Audio Players & Recorders
We hooked it up to a usb but we cannot copy music to our mp3 player what do we need to add to our computer to do so we have windows media player and that is what we are trying to download some songs into...
open WMP (windows Media player)... import what songs/albums into WMP. connect your mp3 to you computer. WMP should recognize it if it is a sansa. Highlight what songs you want right click ...add.. to sync list. or you can make a sync list on the right hand side of the screen and drag and drop the songs you want on your mp3 player ... when you have the ones you want click on the sync button and those songs will xfr to the player
Oct 18, 2009 | SanDisk Sansa Clip MP3 Player
Sony nwz s544 mp3 player won't sync/add songs, running too slow?
why dnt u try opening the file and jus dragging the songs on =] good luckk
Oct 16, 2009 | Audio Players & Recorders
Cannot add new music or access previously loaded music
I know you hate to do this,..but reset your sanDisk, first,..if you've done this and it still doesn't allow you to add,..you will need to make a change in your settings....go to USB, then make sure you have selected "Auto Detect".
Jul 07, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Cant add songs after i made space
Have u checked if the songs u put in have extensions that are supported by the player............in ur case check if some of the songs are .rm or something and not .mp3...........only files with .mp3 extensions will be supported
Aug 28, 2008 | SanDisk Sansa e250 MP3 Player
Computer doesn't recognize songs on the player
Go to disc utility and click on erase volume, then you will be able to add new songs. Unfortunately, as far as I can tell, you may have to delete the entire volume and start over.
Jan 11, 2008 | GPX MW3816 MP3 Player
My computer doesnt recognize my sansa
their are over 11000 problems with this sansa 4GB player. IT is strongly recommended not to buy this ...My screen frozen, computer undection USB, songs deleted by itself, something error.and ETCCCCCCCC>.. latino, ur right, try reseetinn it , then unistall drive..might fix the problem..good luk ..
Oct 30, 2007 | SanDisk Sansa e260 MP3 Player
Pearl Mp3 Player
Once a playlist is created, you must remove the entire playlist from the mp3 player to re-add a playlist with additional songs on it.
-Tha Mp3 Doctor
Aug 20, 2007 | RCA TH1101 MP3 Player
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
