Question about Samsung LE26R71B 26 in. HDTV-Ready LCD Television
HDMI connect problem. ''No signal'' message on Samsung LCD screen
No signal on Samsung 26'' LCD screen when connecting HDMI cable from laptop to LCD screen.
I use Fn + F7 key to get Windows 7 options for diff. projector options.
It used to work easy from the Sony VGN-FW51JF laptop with a HDMI cable to IN port to Samsung LCD screen.
Any good solutions on this problem??
ginko
  • 19396 Answers
SOURCE: Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Posted on Jan 02, 2009
SHOGUN125
  • 58 Answers
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Posted on Jan 31, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
  • 127 Answers
SOURCE: I have a Samsung Series 6-650 LCD TV (Model #
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Posted on Mar 02, 2010
  • 8457 Answers
SOURCE: I have a Samsung LW32A33W
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Posted on Aug 12, 2011
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
"No Signal" Message when using HDMI Inputs on 26" Proscan LCD TV
You MUST get HDMI Driver for your Video Card, it is NOT standard. You need to go to PC makers web site and download latest Video Divers for your PC, then you must set up Multiple Desktops, To do that you must first connect the TV, but leave OFF, connect up to PC, reboot, setup Video Card, turn ON TV, TV will have already been detected, On PC, Share the desktop, or Clone, whatever you wish, now reboot after saving settings. Now you set the TV for HDMI already and it should show you a desktop when chosen. You must select and setup TV, FIRST, then connect the PC. From then on, Turn the TV ON, then turn the PC ON, that way it will Always detect the HDMI port.
Apr 23, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
DVD player and HDTV incompatiblity?
Which ports on the TV are you using to feed the video signal to the TV: Composite (yellow RCA), Components (red, blue, green RCA), HDMI?
Dec 23, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
How do I connect my laptop to a Sony Bravia model KDL-40S4100?
Two options are available to you-
1. Through VGA Cable(Same cable which goes from CPU to PC Monitor)- For Video.
Take to PC Mode from MENU -> EXTERNAL I/P -> PC.
2. Through HDMI Cable.
Take to HDMI Mode from MENU -> EXTERNAL I/P -> HDMI.
If Still No Video
CASE1- 'NO Signal' Message Comes, then toggle the laptop screen with Function Key (depending upon laptop company).
CASE-2- 'Un-Supported Signal' Message comes then adjust the resolution to 1024*768 or 800*600 or as mentioned in Manual.
Please intimate me if any other problem comes after that.
Jun 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
Jan 02, 2009 | Samsung LN-S2651D 26 in. LCD Television
Samsung LE26R71B 26 in. HDTV-Ready LCD Television Logo
222 people viewed this question
Jerry Greenberg
Jerry Greenberg
