My wshing merchine siemens WDI 1140, the spin not working. (My washing wet and watering after completed) please help thanks
SOURCE: Candy CN146
does it spin? It could be the coupler. What type is it?
Posted on Nov 01, 2006
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Posted on Jan 08, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
SOURCE: my siemens washing machine does not spin but the
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
Posted on Dec 10, 2009
Washing machine WDI 12C showing error coed E 06 during wash cycle after an intermittent grating noise was heard several times during wash cycle (possibly on pumping out). Wet clothes and water remain...
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 23, 2011 | Smeg WD16BA Front Load Washer / Dryer
My washing merchine will not spin out the water
the problem is the drain pump motor. 90% chance of an obstruction in the impellar and a 10% chance of the pump being fauly If when you open up the motor and there is no obstruction, check both ends of the pipes connecting to the pump.
Jun 13, 2010 | GE Washing Machines
I have a siemens WDI 1640 washer/dryer which is
I managed to find out the fault code E14 relates to faulty Heating element, product code 494069, and have been quoted £65.00 + Vat for the Bosch replacement. I am yet to decide on how I will proceed.
Dec 29, 2009 | Siemens Washing Machines
My siemens washing machine does not spin but the water in and out functions are normal
Nov 08, 2009 | Siemens WD61392GB Front Load Washer /...
Wshing machine operates but does not rinse and speen.
Try cleaning the filter if its not pumping out water this causes no rinse / spin
Oct 02, 2009 | Washing Machines
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
I have a Siemens Washer/Dryer WDI 1440. The problem is that when I put it to dry, no heat is produced and my clothes are staying wet. What do I do? Many thanks
take top off. you will see dry manifold running across the top with various stats mounted on it. one of these stats will be resetteble ie with a small knob in middle. press and stat will reset. also check continuity thro the dryer heater and the other stats.
if a resettable stat has popped out, check also for lint blockage in the dryer duct
Nov 17, 2008 | Siemens Dryers
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
