Question about Samsung Televison & Video
I have a problem with LE32R82B - after 2 years, suddenly TV lost vision that appears only for approx. 1 second after switching on and then dissapear, while sound is OK. What has happen ?
zjut
  • 106 Answers
SOURCE: lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Posted on Jan 01, 2008
Pyrhyc
  • 2028 Answers
SOURCE: logik tv lcx27wn2 sound but no picture
the only info I could find on this is one withthe same problem. Replacingthe monitor had no effect and the store exchange it.
Posted on Jun 18, 2008
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Posted on Sep 28, 2008
  • 7 Answers
SOURCE: tv turns on for a second, then image and sound disappear
Sounds like a power board problem.Does the tv return to stand by?Red led
Posted on Jul 11, 2009
  • 92 Answers
SOURCE: Visio 42in. Plasma TV
The TV is a Plasma, it does not have a "BackLight" as it were, that is for LCD's only.
Vizio are fobbing you off. It will need either a Y-Sustain & Buffers or a Z-Sustain.
Posted on Sep 07, 2009
My LG42LD420 suddenly lost all tv channels and i have checked the antenna which works on my other tv...pleeeease assist
THE TUNER OF YOUR LG LCD IS NOT WORKING REPLACE THE TUNER BEFORE CHECK THE OPERATING SUPPLY (VCC VOLTS).
Aug 21, 2012 | LG 42LD420 FuHD 42 1080p LCD TV with 2 x...
The TV will switch on and a green light appears, however that is all.No satellite feed at all. I have unplugged the TV for 3 days and nothing. This TV is only 2+1/2 years old.
Firstly there are too many variables on your set up without more info but you could get hold of a small portbale set and plug the sat feed into it via the scart if poss, this will rule out the state of the feed.secondly can you tell me if the other av inputs on the raer of your set provide sound and vision ok using a dvd, vcr etc, cheers for now.
Nov 03, 2010 | LG 37LC2D Television
Region free Samsung Blue Ray player BDC5500
this is already a regional (plays all 6) free (at least this model is suppose to) player.
you can also update your players firmware from the link below.
  • http://www.samsung.com/us/function/search/espsearchResult.do?keywords=Samsung+BDC5500+Player&input_keyword=Samsung+BDC5500+Player
Jul 26, 2010 | Samsung BDC5500 Player
My TV suddenly has a big black rectangle in the lower center part of the screen, that dissapears only for a few seconds when pressing any button. How can I remove it?
Sounds like your Closed Caption has gotten turned on. Try this solution...
1) Press the MENU button
2) Use the CHANNEL UP/DOWN to scroll to CLOSED CAPTION
3) Use the VOLUME UP/DOWN to until MODE is OFF
4) Use the CHANNEL UP/DOWN to scroll to FINISH
5) Use the VOLUME UP to save and exit.
This should make the box go away.
Good Luck.....
Jan 19, 2010 | JVC AV-27F802 27" TV
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
How to turn off the progresive scan
This is frustrating but what worked for me:
1. first make sure you are on CD/DVD mode
2. select the 'Setup Menu' button so that the words 'Setup' appear 3. press the 'CH/TRK Stop' button (it is blue on my remote) and hold it down (approx 5 seconds) - if it works, the setup menu will be displayed.
If this does work - write the instructions on a small index card and glue it to the DVD player ;>P
Dec 21, 2008 | Televison & Video
LCD Screen problem
You have a failed inverter circuit. This is a very common fault with BenQ and other LCD monitors. I have seen more FP737 and FP731's and all their cousins in the last 2 years then I care to count.
You will be best to take it to a TV technician and have them do the repair. There are ways to fix it yourself, but the chances of success are not great without a decent amount of electronic knowledge.
Call several places and get approx quotes based on the inverter fault. A lot of TV techs will not work on LCD monitors and is another good reason to call around first.
One final thing, check the manufacture date on the back of the monitor, these normally come with a 3 year warranty and it will be either expired now, or very close to it. If it is still under warranty, then contact BenQ near you to facilitate the repairs.
BenQ support webpage.
Apr 15, 2008 | BenQ FP731 17" LCD Monitor
Televison & Video Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
