Question about Canon PIXMA MP530 All-In-One InkJet Printer
WHY CAN'T I JUST PRINT WITH BLACK INK ON THE CANON MX320?
    Scholar:
  • 126 Answers
This is possible-
go to the control panel - double click 'devices and printers' then in properties of your mp530 select the 'print in black and white' check box.
Posted on Aug 01, 2010
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
  • 1606 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
SOURCE: Canon i250 won't print in black
I had this problem also. There were short-term solutions, but nothing worked for any length of time. In the end the only solution was to buy a new printer.
Epson have deliberately built obsolence into these printers. After a pre-determined number of prints, they just stop working. Clever fixes keep them limping on a bit longer, but eventually you have no alternative but to replace them. On principle, you should therefore replace your planned-obsolescence printer with a non-Epson machine. But then you'll be left with your stock of cheap Chinese printer cartridges!
In the 1960s Ralph Nader made his name as a consumer champion by campaigning against US car companies. They used to build in pre-programmed obsolence into your car so that after a certain amount of time you were forced to buy a new one. Just like Epson is doing today.
Posted on Apr 07, 2010
rulds2008
  • 3866 Answers
SOURCE: canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 26, 2010
alpug
  • 1961 Answers
SOURCE: How do I change the ink on my Canon MX320...
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
Posted on Sep 14, 2010
Why wont my color ink work in my canon MX320 printer?
Take out the carriage and soak it in solution for 24 hours to clean the jets
Sep 26, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
Tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
on Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
HOW DO I USE ONLY ONE INK CARTRIDGE FOR BLACK INK ONLY
Go the printer preferences, click on tools - click on ink, the choose black only. if you select black only, it will just print black, even with color pic
Jan 03, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
My print is Canon MX320. I just changed a new ink, but the error 5200 occured. Do you know what happened? Thanks.
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on, if error still persist replace ink cartridge or print head.
Jan 30, 2011 | Canon Office Equipment & Supplies
I have a canon pixma mx320. I purchased on line refillable ink cartridges. The problem is the printer will not let me copy, print or even fax. The screen keeps reading black ink volume level not readable....
Go into the Canon Printer Utilities. Click on Solution Menu folder. Click on Solution Menu icon.
A new window will open up. Click on "Change settings or find solutions to problems.
A new window will open up. This screen will give you 3 selections to choose from.
They are: Printer Settings, Printer Status and Troubleshooting. You will be able to reset your ink cartridge levels from these windows and try to print again.
Dec 22, 2010 | Canon Office Equipment & Supplies
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
335 people viewed this question
old marine
old marine
