Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
At the end of the washing cycle the Fabric Softner section of the tray is always left full of water. This is on a BOSCH WFT2800 Washer/Dryer
  • martin_jo831 Aug 01, 2010
    Thank you very much, most helpful
    President:
  • 1,554 Answers
Pull the dispenser drawer out until stops then push the locking tab down the pull the dispenser drawer out completely. Lift the fabric softener and bleach compartment insert and you'll see the tubes both on the insert and the drawer. It is in these tubes where the fabric softener is being dispensed through by siphoning action. Clean both tubes and make sure they are aligned properly when reinstalling and the end of the tubes on the insert are not touching the drawer.
At the bottom of the drawer is the conveyor which guides the fabric softener and the bleach to the dispenser outlet. Clean the conveyor and the dispenser drawer cavity to make sure the dispenser outlet is not clogged.
Posted on Aug 01, 2010
  • 1 more comment
    Thank you for this quick reply. I have however already tried giving the whole of the drawer a good cleaning. I have also cleaned the pipies that connect to the drawer cavity, but the problem persists.
  • Jahn27
    Jahn27 Aug 01, 2010
    Lay the drawer leveled on a flat surface then gradually add water into the fabric softener compartment until it is full. Water should start flowing through the tubes to the bottom of the drawer into the conveyor. Otherwise, check the alignment of the tubes or consider replacing the drawer.
    Did some checking after your second reply and foun that the washer is no longer standing level, it was tilted forward. This explains why the water was not syphoning out completely.
The fabric conditioner drawer is always full of water at the end of the cycle, i have tried cleaning it and running the machine empty but nothing has worked.
fabric conditioner drawer is always full of water This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2011 | Washing Machines
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric...
I have a Bosch front load washing machine bought approx. 2006 model no. WF02467GB/01. The problem is that the pre wash draw section is taking in water towards the end of the wash cycle and the fabric conditioner section is remaining full of water
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Water being left in the dispensers when the washer cycle is done
Water in the fabric softner slot is normal, but for the detergent slot you have to clean out with a tooth brush if you can't get the tray out. If there is water there it is quite a serious block, which is affecting your wash.
Mar 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Fabric softener always left in tray
hi there are you using concentrated softner if so water is down as some softners are to thick to go through the dispenser also give the whole drawer a soak in hot soapy water incase there are any blockages.
hope this is of some help
Nov 11, 2007 | LG WM-1480FHD Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hoover H120M Washing Machine No fabric softner and dial clicking round
always check your carbon brushes which are situated at your motor covered in a plastic covering must be at least 8ml long these start at 1inch in length may not be giving enough contact to your motor for the timer to click into action m8 but if these are ok then it will be more than likely your timer which is faulty with it not doing the water inlet valves properly
Nov 03, 2006 | Hoover H120M Front Load Washer / Dryer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
330 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
