Question about Nokia 1600 Cellular Phone
Led problem - Nokia 1600 Cellular Phone
  • Nokia Master
  • 2,148 Answers
Posted on Aug 01, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Tip
GSM alarm system with RFID & APP control and Touch keypad
Name:GSM alarm system with RFID & APP control and Touch keypad
Memo:
products introduction
??Features:
??Multi-languages voice; system volume is adjustable (low, medium and high);
??99 RFID cards to arm, disarm, and control the relay;
??SMS notification for disarm by RFID card; SMS content (of the first 10 cards) is editable;
??12-second voice message: by control panel or remotely;
??Broadcast system time and play voice message;
??Use panel as a telephone to make calls;
??Set the by control panel, SMS or remote calls;
??10 remote controls, 99 wireless and 2 wired defense zones;
??Sensor low power alert and tamper alert;
??Some of SMS alarm contents are editable;
??SMS alert for control panel tamper, low power, power failure/ recovery;
??Remotely control the relay.
REV M White SUNRAY 800 HD SE SIM 2.10 Card SUNRAY DM800 HD SE A8P ALPS M Tuner SUNRAY DM800 HD PVR SIM210 with Wifi HDMI SIM 2.1 Cable receiver.SUNRAY DM800 HD SE A8P card SUNRAY DM800 HD SE A8P card ALPS M Twin Tuner SUNRAY DM800 hd Pro Alps Tuner REV M SUNRAY DM500 hd Pro satellite Receiver ,wholesale cheap discount price.alarm security systemVU SOLO 2 SE Twin tuner SOLO MINI 3LED DisplayLED signLED Display ScreenOUTDOOR LED sign large LED DisplayOUTDOORLED SIGN BOARLED DisplayFlexible CurtainLED Dance Floor Display FullCOLOR OUTDOOR Led Sign led screenoutdoor led displayled displayindoor led displaytransparent led displayled display lightingled video wallchina led displayfull color led displayled screensflexible led screenrgb led displaylarge led displayled curtainled dance floorfull color led displayout door led displayled display manufacturerssmd led displayled dance floor for saleled display, led curtain, led mesh for stageoutdoor led screenadvertising led displayindoor led displaystransparent led screenled meshled displayled screenA8p card SUNRAY SR4 V2 Rev.E jynxbox store
dreambox dm800 hd se v2alarm security systemdreambox dm7080dreambox dm7080dreambox dm820dreambox dm7020 hd v2cheap wholesale dreambox dm800 hd v2Sunray SR4 V2 Sunray SR4 800 se Sunray SR4 hd se JynxBox Ultra HD V14JynxBox Ultra HD V16JynxBox Ultra HD V15Dreambox DM7080 HD PVRDreambox DM820 HD PVRDreambox DM8000 HD PVRDreambox DM7020
on Mar 29, 2016 | NU -set Gsm Padlock Alarm System -...
I need a simple wiring diagram to turn on 40 red leds and 40 green leds on a 9volt battery
Two ways to do it..........
One is a Series circuit, the other is a Parallel circuit.
Of course you can also use a Series/Parallel circuit.
Each LED has a Positive ( + ) connection, and a Negative ( - ) connection.
A) Series circuit:
One side of Switch is connected to Positive ( + ) of the Battery.
The other side goes to the Positive ( + ) of the first LED light.
Then the LED's are connected together in a Series.
Negative of first LED light to Positive of second LED light.
Negative of second LED light to Positive of third LED light.
Negative of third LED light to Positive of Fourth LED light.
And so on, and so on, until you come to No.40 LED light.
It's Negative connects to the Battery.
ONE LED goes bad, and none of them will work.
Old Christmas light strings are set up this way.
B) Parallel Circuit:
Switch to Battery - Positive ( + )
Wire goes from Switch, to 1st LED light's Positive connection ( + )
Then wire from 1st LED positive, to 2nd LED Positive ( + )
Then wire from 2nd LED Positive to 3rd LED Positive.
And so on, and so on, until you reach the 40th LED.
Then wire comes from Negative ( - ) of Battery, to Negative of 1st LED.
Wire from 1st LED to Negative of 2nd LED.
Wire from 2nd LED to Negative of 3rd LED.
Wire from 3rd LED to Negative of 4th LED.
And so on, and so on, until you reach 40th LED.
Wire connects to Negative of 40th LED. Then a wire connects from 40th LED Negative, and goes to Negative of Battery.
http://en.wikipedia.org/wiki/Series_and_parallel_circuits
Series Circuit;
http://en.wikipedia.org/wiki/File:Series_circuit.svg
Over to the Left side you see the Battery symbol. There is no switch in this circuit.
In the Battery symbol, the Longer line represents the Positive pole.
(Positive connection)
Resistors are represented by the squiggly lines. In place of them put your LED lights.
A Switch would go in-between the Battery, and first LED light; on the Positive side.
(ALWAYS put the Switch on the Positive side. Can explain in detail if you need)
[The Top line in the diagram, is the Positive 'wire' ]
http://www.autoshop101.com/trainmodules/elec_circuits/circ114.html
Parallel Circuit:
http://www.autoshop101.com/trainmodules/elec_circuits/circ122.html
In a Parallel circuit, if one LED light goes out, the rest stay on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2013 | Computers & Internet
What is an Samsung UN40D6500 LCD TV? LCD TV Liquid Crystal Display, which stands out from the bulb or CCFL Cold Cathode Fluorescent Lamp, which is a thin tube like a drinking straw. By horizontal long as...
Hello
What is this? Are you trying to take a class to everyone to thie world, how the LCD TV works? I think you be a student, not a professional. If you wer a professional, you may won't dare to post this as a problem. OK.
Feb 11, 2012 | Computers & Internet
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Nokia 1600 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
